Introduction: "Sweet" Ribbon Dispenser
I love collecting scraps of ribbons. It can be an unused bundle I found in a corner of my house or a bunch of leftovers from a school project. I save them all up because you never know when you need it for gift wrapping or other crafting projects again.
But sometimes seeing those piles of ribbons can get rather depressing. Then I saw that TicTac on my table and I knew it's time I did something about my problem...
Note: This tutorial was done ages ago and has been on CutOut+Keep for quite some time. It's my first ever How-to then so pardon the blur images. I just wanna share this idea with the people on Instructables. (^_^)
Step 1: Grab
Grab that messy, distressed pile of ribbon.
Step 2: Eat
Finish a container of TicTac. You don't have to finish all at one go!
Peel off the label slowly to make sure that you get a non-sticky container.
Remove the cover.
Remove the cover.
Step 3: Roll
Roll the ribbon up neatly. This may require a bit more patience!
Then insert the roll of ribbon into the container. One shortcoming of this dispenser is that the roll cannot be too big, if not it can't fit into the container at all.
Step 4: Leave Tail
Make sure you leave a tail of ribbon (about 1 cm) outside the container.
Step 5: Line Up
Line the cover and the direction of the ribbon as shown.
This arrangement helps ensure a smooth dispensal of ribbon.
Step 6: Replace Cover
Replace the cover with the ribbon tail peeking out of the opening like the one shown in the picture.
Step 7: Close Cover
Close the cover while leaving a tail peeking out from the SIDE of the cover.
Do not leave the tail peeking from the front as the crease at the front may spoil the ribbon!
Step 8: Tape
Tape the container lengthwise. You can use coloured tapes to decorate the dispenser.
The tape is needed as TicTac covers become loose after the removal of the label.
Step 9: Dispense
Open the cover to dispense ribbon as and when needed!
A neat and green solution to your piles of distressed ribbons! (^_^)
Step 10: Tips
TIPS: Other potential dispensers are candy boxes with just a small opening but big, roomy body. But the good thing about TicTac containers is that it is clear, so we can see the contents!
