Swiffer Mop Pad (a reusable one!)
Sew a reusable pad out of old t-shirts and a wool blanket for your Swiffer-type mop.
I do not like using disposable cleaning products. I cloth diaper my kids and I use washcloths instead of paper towels. But my Swiffer mop is so convenient! It seemed to me that it was time to stop using disposable mop pads. It will save the environment and save money.
I decided to make this pad out of discarded clothes and a wool blanket I never use because I did not want to throw them away either. The greatest part about this project is that anyone can do it. It does not need to look pretty. You're going to use it to clean your floor, you know?
Cleaning with this pad takes a little more elbow grease than the disposable pads but it cleans great. I recommend making at least two so you have a clean one while the other is in the laundry.
Step 1Materials List
Materials List
An old t-shirt
Woven wool blanket (or anything you have on hand that will stick to your mop head)
Disposable pad that comes with your mop
Pencil
Freezer paper
Iron
Ironing board
Scissors or rotary cutter
Pins
Sewing machine
Thread
46 comments
1-40 of 46next »
Aug 11, 2007. 8:58 PMmcadwell says:
Hmm, my Swiffer mop must be different than you guy's. I just put a regular sized washcloth on the floor, set the Swiffer mop on top and stuff the washcloth corners into the slots on top to hold it in place.
Oct 9, 2011. 8:16 PMjcolip franke says:
I've had both types of swiffer mops. There is the one described above that you can get both dry and wet cloths for and then the wetjet that has the liquid cleaner bottle attached. I've broken both of mine. I was going to get a new wet jet but I'm going to get the other because I really like the idea of using a washcloth with it. It seems it will be easy to rinse good and reattached during mopping of my floors. Then I can throw the washcloth in the laundry.
Aug 14, 2007. 9:50 PMmcadwell says:
It is easy. Wet the washcloth in the cleaning solution, wring out and stuff in the corners. Take off and throw in the washer. Your cleaning pad looks nicer though. :)
Jul 17, 2008. 6:59 PMterryperry says:
you may also try sewing a piece of tulle (that net like fabric used for ballerina tutus) to one side so as to imitate the swiffer scrubber side. 'Just to get the dried on tomato sauce off the floor.'
Oct 9, 2011. 8:10 PMjcolip franke says:
I like this idea too!
Aug 8, 2008. 11:43 AMAlisonM says:
Fabulous idea. Back when I had a cleaning service, they'd tie rags onto to mops so they could toss them when they got dirty instead of just moving the dirt around, and I was trying to think of how to do this for the pet rescue I volunteer for. We started using the swiffer wetjets, but you can easily use two pads a night, and the cleaning fluid lasts barely a week. I've got tons of t-shirt rags, and now I know what to do with them! I might also try cannibalizing some delicate bags (the kind you use in the washing machine that are always opening at the seams or breaking their zippers) for a "scrubby" surface for the bottom. Thanks for the Instructable!
Oct 9, 2011. 8:09 PMjcolip franke says:
Delicate garment bag idea is fab!!
Aug 29, 2011. 11:05 PMescapefromyonkers says:
i tend to break the aluminum pole, when i mop broke 2 or 3 already, now i use the painters stick,or s hardwood stick, i had a duster /dry type that came with wet and dry pads, there is an instructable to refill the reservoir from the top, no need to mess with the treads and leaking, i use the yellow synthetic microfiber pads that costco sells in the auto section, work great and eaaasy to clean, plus bag of 48 is cheap and useful all over the abode. i added velcro to the bottom, but i am changing to the stick 2 by 2 or the rubber scrubbers head that i also have , abd had no use for.on the wood one could always nail some extra padding.i am going to make a small 4 inch one for behind the toilet. the old mops dont hold a candle to small microfiber shop rags
Apr 20, 2011. 9:41 PMstrayler says:
I made some reusable pads out of old sweat pants. I made them with the fuzzy side out. You can double or even triple these in thickness. Depending on how thick you want them. I tried them for dry dust mopping. They worked really good.
Jan 11, 2011. 3:12 AMMariacleaning says:
It's a great idea! Maybe I also will use such mops while providing house cleaning services to become even more environmentally friendly!
Mar 30, 2008. 8:21 AMMAGS76_2006 says:
I have used maxi pads in the past. They work well and are cheaper than the real thing. The hospital maxi's, that are as big as diapers, work the best.
Nov 9, 2010. 8:15 AMallnamestaken says:
I have done this.....bough large store brand maxi pads. Thought I was the only one! ha ha! But still want to stop the waste and expense. I'll be making some of these.....white....so I can bleach them clean! THANKS KIBBLESNKNITS!
Jan 3, 2010. 9:05 AMKittyF says:
Now that's a great idea for those who no longer need those things.   I wonder what I did with mine.   LOL
Jul 14, 2010. 12:30 AMSparkleCleaning says:
I am admired by idea of the author. I already long time think of equipment of workers by similar things. Then I save expenses of company Seattle House Cleaning and I show care of an environment.
Jan 3, 2010. 3:18 PMAmyLuthien says:
AH!  Definitely forwarding this one to my mother!  She's a quilter, I've often claimed she can quilt anything and this just goes to show, you CAN! :D
Thanks!
Jan 3, 2010. 10:23 AMkayann says:
Along the lines of stickmop above, I moisten a reusable rag, toss it on the floor, and use a scrub brush on a stick to push the rag around.  It works great and gives you plenty of traction to scrub stuff that sticks to the floor.
You can buy these brushes at home centers for refinishing your deck - basically a rectangular brush on a stick so you don't have to bend over.  They are also good for picking up large quantities of dog hair off of a tile floor - I used to work in a dog kennel and we'd use this type of brush to pick up dog hair that gets blown around.
I break out the real mop (whose head is washable) for major cleaning - but find the rag/brush combo great for wiping up all those little spills that accumulate between cleanings and make the floor look grimy.  When I'm done I toss the rag in the washer.  Hooray for reusable cleaning supplies!!
Jul 8, 2007. 12:28 AMvoodooduck says:
This is great! It makes me very happy! Thanks Kibblesnknits! :D
Jan 3, 2010. 9:07 AMKittyF says:
Ferget about the tree, drive past a landfill once and you'll feel so virtuous.  LOL Kitty
Nov 1, 2009. 8:29 AMmargaret swain says:
Am I missing something, how do you attach this to the mop.
Sep 3, 2008. 5:25 AMpesci says:
i purchased a swifer jet a few months ago and when I went to replace the bottle of solution it was too big. I have looked for the smaller bottles but can't find them anywhere. has anyone has this problem?
Oct 10, 2008. 10:29 PMValancy says:
If you would like to reuse the bottle, you can get a large syringe tube from a feed store ( a bolus syringe ). Use this to refill the bottle with your own combination of cleaning solution. Simply use the syringe to suck up the cleaning solution, and then inject it into the empty swiffer bottle through the soft plastic section of the bottle.
Sep 5, 2009. 12:54 PMparisbabe says:
you can also take a monkey wrench and carefully twist the plastic top off the disposable bottle and refil it with whatever and then twist it back on. This has worked for me alot of times. It will only work for a few times before it leeks but its worth it.!!!
Jul 13, 2009. 3:01 PMvintagecharms says:
My boyfriend got the top off with an adjustable wrench with a towel to keep the wrench jaws from messing the top up. THe wrench strips the pieces inside the top that keeps you from just unscrewing it. I refill with a more pet friendly cleaner.
Aug 19, 2009. 11:49 PMstickmop says:
I use bar rags on my stickmop. Yeah, your basic stick with a crossbar 2x2 at the bottom, just like you see all over Mexico. Easy to make free. The rag just folds over the bottom crossbar/stick.
Jul 5, 2008. 4:56 PMChibbie says:
Why on earth would you waste the time and go to all the trouble to make one of these things when you can just use a regular mop??? You people must have more time on your hands than I do.
Jul 13, 2009. 3:04 PMvintagecharms says:
Because I went thru 3 mops last year and the sponge refills are either impossible to find (The store stops carrying them) or they don't clean my kitchen floor well enough (they are made carpy) and my frustration went sky high. People have reasons for what they do. Yikes! Yes, that was nice!
Jul 17, 2008. 7:06 PMterryperry says:
SOmetimes a mop is better- but it really depends on the job at hand. Swiffer is a good alternative if you are doing just light cleaning or everyday maintenance on a floor. A regular mop requires lots of water (and sometimes back breaking, hand cramping effort) to keep the dirt from re-depositing itself.
Using a swiffer also allows the floor to dry more quickly, which is really convenient if you have high traffic areas.
Its good to have these Instructables around!
Jul 13, 2009. 2:59 PMvintagecharms says:
I have been using cut up tee shirts for several months now. It does need the padding. I would buy one from you for $5.00. Shouldn't cost more than $2.00 to ship.
Mar 22, 2009. 1:37 PMmackdarra says:
what i did was i used a big microfibre bath towel and made a number of cloths v cheap and v efficient and everlasting ---well almost
Jan 6, 2009. 8:55 AMbutterbean says:
Aw, heck, and it's pretty too LOL. Great job, great tute kibblesnknits! Thank you!
Nov 23, 2008. 9:12 AM4sweeper says:
Try using a microfiber cloth. They stick well to the velcro on the swiffer and do a great job of cleaning.
Aug 29, 2008. 9:57 AMkatymay74 says:
oh wow. my son uses cloth diapers with the big absorbent pad in the middle. now i know what i'm going to do with them when he's done with them.
Aug 22, 2008. 5:00 PMskincage says:
Thank you for properly demonstrating an idea that's been in my mind for some time. I was using a washcloth as a pad replacement but this is far more classy. Well done.
Mar 20, 2008. 10:09 AMcpd_trigger says:
This is great! I think I'll try it with an automotive sham. Super absorbent.
Feb 22, 2008. 4:16 PMreach8157 says:
I love the use of a cloth diaper. They are great, and leave no lint. I have noticed though, that the swiffer refills for the wetjet, look an awful lot like an Always maxipad. Have you thought of trying one of those? I might, just to try it.
Jan 22, 2008. 12:11 PMDragonsCat says:
I can't believe this didn't occur to me! I even get angry at Swiffer commercials because the clean-by-creating-more-trash concept irks me so. But, they do look like they would clean better than our spongey mop that just sort of moves the dirt around (and is nearly impossible to get the sponge clean). I'm definitely going to try to make one of these to replace those sponges; hopefully it'll clean the floors better as well as being easier to clean itself! Thanks for posting :D
Jan 19, 2008. 8:04 AMjessyratfink says:
This is such a cool idea! I hate buying new pads. It seems silly to spend so much money on one-time-use items.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:kibblesnknits
I am a stay-at-home-mom and crafter. I'm always coming up with schemes for how to make things we buy reusable, better, or more beautiful.
