3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Swiss AVR Knife
Step 12Preparing the Audio Jack
The wires to the audio jack are all quite short. Apply a bit of solder to the pins on the jack and the wire and then solder them in place. Slide pieces of heatshrink tubing over the joints to protect and strengthen them.
The ground wire can be soldered directly into its hole. The ends of the signal wires each share a hole with one end of a resistor. Prepare the wire and resistor by twisting the ends together and applying a little solder. The hole into which these go should be drilled to 3/64" to accommodate the two wires. Solder into place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
