Step 3AVR Programming Tools
Programming cradle
I based mine on the Ghetto Programming Environment. The long pins of the wirewrap chip holder extend down in to a breadboard and makes for a convenient experimental setup.
The only problem I have encountered is that the components from the programming pins cannot be grounded during programming. I have taken two approaches to solve this problem. The first is to have two chip holders, one for programming and one for running (see 8-pin cradle). This is not ideal because it renders a lot of the breadboard unusable and it is quite annoying to move the chip. The second is to install a small switch to disconnect the ground pin from the ground of the breadboard during programming. This works better and leaves more space on the breadboard for components.
Programmer
USBtinyISP kit from Adafruit Industries. With a little modification (remove the 10-pin cable and bend the LEDs) the programmer fits in an Altoids Gum Tin. The 6-pin cable can even be coiled up into the tin for storage.
Software
WinAVR is a collection of open source software development tools for programming AVR microcontrollers on Windows machines. It works well with the USBtinyISP programmer (see the AVR Tutorial).
I recently switched from using the Programmer's Notepad application that comes bundled with WinAVR to using Eclipse with the AVR Eclipse Plugin. Eclipse can use avrdude, so you will have to install WinAVR anyway. Eclipse has better project management, helpful tutorials, and is free. It took just a few minutes to install it, work through a tutorial, and program a chip.
Phone a friend
There are lots of resources on the Internet. Look for them, ask for help. People can be knowledgeable and helpful. That's nice :-) They also can be dismissive. That's not nice :-(
Add Comment
