3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Swiss AVR Knife
Step 5Breadboarding the Project
Because so much of the work of this project is done by the microcontroller, there are very few external parts. After checking that your programmer and tool chain are in order, it would be a good idea to breadboard the circuit and make sure that everything works as advertised.
The pictures below are messed up versions of the actual breadboard I had set up. I used the LEDs in the model tin and pried out the cradle and chip to use in several photographs. The overall wiring basically connects active pins to a few parts and then on to ground.
Note The order of pins and LEDs is not the same on the breadboard and the PCB (although I suppose you could make them the same). In the code, you will see pieces of code that need to either be enabled or commented out depending on whether the target is the breadboard or the PCB.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
