3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Swiss AVR Knife
Step 7Designing and Making the PCB
There are numerous resources on the Internet that describe the process of creating PCBs. None of the methods is foolproof or easy, but it is important to get comfortable with at least one.
I use the the freeware version of the EAGLE Layout Editor from CadSoft to create the schematic and layout the printed circuit board. My approach to manufacturing the PCB is described in the Making and Preparing the PCB step of the Altoids Tin Speaker instructable.
After transfer, etching, and drilling the board, you are ready to solder everything together.
Note My most recent experience for transfer images to circuit boards is the following. Wash the board well with dish soap and scrub it with a green scrubby. Gently sand any burrs off of the edges of the board so that the transfer paper and iron make good contact with the board. Preheat the iron. Place a piece of paper on the board and the heat the board with the iron. After the board is quite hot, carefully place the prepared transfer paper on the board. It will stick right away (because the board is hot) so make sure that it is correctly positioned. Then iron directly on the shiny back of the transfer paper. This never caused me any trouble, but you are using your own iron. Test first. Let the board cool and then run it under cold water. The transfer paper should pop off and leave the entire image. Use an 8x slide/negative viewer to look over the transfer and fill in any missing pieces. Good luck.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
