Introduction: Multi-tool Keys - Mod / Hack
Modify your keys to fit in a leatherman. This is a real clever way to pack some spare keys around. You can fit up to six keys in one mini multi-tool.
Step 1: Materials
Also Stop by http://mathewmullen.com for more cool projects.
Materials
Leatherman Micra - ( I used a cheapo Husky clone that I got at home depot for $2)
Keys - (be sure to make copies of them first)
Drill
Something to cut the keys with - (I used a Dremel with a cutoff wheel.
Step 2: Disassemble the Multi Tool
Step 3: Select a Matchup Piece
Step 4: Cut Your Keys
Step 5: Mark and Drill the Holes
Once you have marked all keys, mark your starting points with a punch or nail and drill your holes. The size of the hole may vary depending on what kind of multi tool you choose. Start small as you can always bore it out more if necessary.
Step 6: Put It Back Together
Re-assemble the tool substituting the keys for the tools. Be careful of three things. 1) Be sure you put a washer in between any metal-on-metal contact. 2) Make sure you place the keyring attachment piece somewhere where it will not interfere with a key. 3) Most importantly, remember to leave a gap in the middle of each side for the pliers/cutters to fit into when you collapse the tool. ( I placed two keys all the way to one side, then a bunch of washers and then a key against the other side.
One little tip: If there is a skinny leather punch or mini screw driver piece, you can stick this through the hole when re-assembling the tool to help keep the washers and the pin in place. This also worked well to wiggle around to get everyting to fit together properly.
I was thinking for my next attempt to use a slightly wider, folding style alan wrench set and try to get a bunch on each side.
-Pyro222
