Switch Box for Your Sound/headphone
Introduction: Switch Box for Your Sound/headphone
If you are like me and have problems to switch your sound with headphones in you computer.
Materials' list:
1 dual channel switch (for stereo) - Mod. 17203 in this case;
3 female P2 (3.5mm) in my case - from old pc sound board;
• 1 mini box - I don't know where I found it :);
8 wires - net wire;
Accessories and tools:
  • Glue;
  • Sandpaper (#300 and #600);
  • Drill;
  • Soldering iron;
I put three female connectors because all my cables/extensions are male. If you prefer, you could use a cable soldered internally.
Step 1: Preparing Wires, Connectors, Switch and Box
Prepare your box making the roles for each connector and the switch, Fig. 1. I put all components reaching the back of the box, so I can glue all of them.
After making the roles, I sanded the box to give it a mat aspect - you could see through it but not clearly, Fig. 3 and 4.
Now we should prepare the switch with the wires, because it is easier if you put the wires in the switch before you put it into the box; remember, you have two independent channels, so use colored wires to keep organized. The third wire color you will use to the GND - I use a green one, Fig. 2 and 5.
For some schemes of those jacks see here.
After all parts are OK, you should glue the connectors and wait to be fixed. Then you easily weld all parts together, Fig. 5
Step 2: Finishing
You could use a metallic box to keep it shielded. But I've tested and I have no noise in this current configuration.
You should test (including with a multimeter) to check the resistance and short-circuit.
TIP: If you build like me, when you turn the switch to the left, you will activate the right out. If you prefer to keep the same side, turn the switch 180º.
I used a double-sided tape to stick it behind the monitor.
TIP 2: You can use the foot monitor to hold your headphone like the last picture. Enjoy!
Comment: I would like to see a monitor with a frontal-bottom output for headphone. All that I see have a back output that is unusual (or unpractical).
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
  • Paper Contest 2018
    Paper Contest 2018
Hi! Nice project! In fact, I actually just made one and it works fine, but the sound is verry bad and I don't know what I could do to make it better. I don't know if you can help, but thanks in advance!
Hi! Could you send me more information about your project. Some pictures for example would be nice, so I can help you. Tks! You said that the sound is bad, how are you comparing them?
Hi! Thanks for answering! Here are some pictures of the finished product. I'm not sure I understand your question about how I'm comparing them... It's just that the sound quality is poor (actually, very very poor). If I do well understand though, it's just that the signal which goes through the switch is has downscaled vocals (or downgraded or degraded -- sorry for my English, not my native language). The instrumental part is kind of fine, though.
Hey, sorry for the delay, these comments sometimes does not work and I don't know why. I have already answered for you, but I will post again. So, this problem you said can be created by the negative (GND). In your photos I don't see any negative wire, just two of them (left and right channels) maybe. This should be the problem. If there is a negative wire, try to check it. If you see my pictures, red and blue wires are positives (R and L channels) and the green one is negative. I hope to hear from you. Good luck!
Thanks a lot! You were right, the problem was just the negative wire! All works fine now! Thanks again for the help and the project!
I'm glad I could help you! Thanks! If you need any help in the future, please, contact me :)
Could you do this with hdmi inputs ???
As far as I know HDMI has 4 differential pairs plus some sort of two wire interface plus additional channels for hotplug detection and ethernet, so at least 10 lines in total. You most likely won't find a switch that big, and if you do it'll be expensive.
Anything with high spped signals is incredible sensive, any difference between both wires of one pair in thickness (resistance) lenght (inductance) and distane to other wires (capacitance) will effect the signal negativly. Thats why you sometimes see on pcbs two traces close together and going in loops to match the lenght. Imagine now at least 20 wires randomly stuffed into a box.
For a simple solution you shoud rather consider to a switch. They would propably cost less than the huge switch alone.
If you however absolutly want a diy solution you should look out for specialy designed ICs. I quickly checked and TI (Texas Instruments) has some nice ICs to switch between two or three lines (2:1 / 3:1) in a small, but hand-solderable 64-TQFP SMD package. For companies they offer a sampling service, so if you ask nicely you might even get one or two chips for free. If you go this way, pleeease share your experience with us. Good luck
I think that this is not a good idea. HDMI is a high speed digital channel, so any bad quality material used could damage your signal. You need do ensure the components quality and shielding. Including to that, may you have problems with sync. If you try, share with us.
would say rca have the same problems as hdmi that you were talking about
