Step 26Heat treating
First, I normalize 3+ times (bring the blade up to the critical temperature then let it air cool).
Normalizing relieves the stresses put into the blade during forging, filing, and sanding.
Then, I bring the blade up to temperature, about 1600F for this steel. Bringing it up a
bit hotter than needed allows me to get the blade to the quenching tank at the right temp.
Next, the blade is plunged into 450F oil and allowed to cool fully to that temp.
Once the blade is at 450F it is semi-plastic and can be molded by a gloved hand.
As the blade cools it "sings" making a shimmering noise as the martinsite crystals form
and the blade reached its hardend state. Finally, the blade is given 3 one-hour heat cycles
at 475F. This converts more of the steel to martinsite, and releives the stress of the quench.
*A side note: I lost three blades in the HT (heat treatment). Also, a blade of these dimensions
will develop a forward curve during the HT so the final blade was forged with a backwards curve
Tempering converts some of the martensite back into iron and Iron carbide.
Also, why three heat treatment cycles? A single two hour cycle should be more than sufficient for this purpose.
there are several different structures that occur in an iron and carbon solution
ferrite (iron)
Iron carbide
Martensite
Pearlite
cementite
austenite
the ones critical to our discussion are austenite and martensite. Generally speaking all martensite is, is an unstable form of of austenite that occurs at elevated temperatures. Rapid quenching freezes the molecules in place and causes the steel to remain in an austenitenitic structure. All you are doing by tempering is allowing some of the steel to return to it's austenitic state.
I'm sorry but whoever gave you your heat treat information was incorrect.
If you quench carbon steel while it's at high temperature (900 C +) it forms the non-equilibrium phase of martensite. Which is hard brittle, and unstable. What tempering does is it returns some of this marstensite into austenite, then into it's other equilibrium phases. Resulting in a more durable blade.
Ben said that tempering turns the steel into martensite, which is just flat out wrong. The only time martensite is formed is during the initial heat, and quench.
Sorry, but your statement about holding the blade in alignment with magnetic north is just ridiculous. It does nothing to make the blade stronger. It's an old smith's tale. Proper heat treatment goes much further.
Don't pretend that the magnetic alignment does anything for the strength of the steel. This does absolutely nothing. The closest thing to what you are talking about is a cooling technique that they use for turbine parts, and all that achieves is an increase in high temperature strength.
