Sword of Altair (Assassin's Creed)
23,191
254
20
Posted in CostumesWeapons-and-armor
Introduction: Sword of Altair (Assassin's Creed)
About: I like to think of myself as a renaissance man. I'm interested in a lot of things, but most importantly I'm interested in learning, being capable, and doing things for myself. I've learned to knit, sew, and ...
This Instructable is a how-to for a wooden prop version of the sword that is carried by Altair in the game Assassin's Creed.
I decided to make the sword in three parts. Handle, Cross Guard, and Blade. Then I used a threaded metal rod to to make sure the connection between the three pieces was secure. It might have been easier to do one piece that started as the handle and turned into the blade and then attach the cross guard to it, but I already started before I thought of that and rather than lose momentum dwelling on how I could have done it I just kept on pressing on.
The supplies I used were:
-Thin pieces of wood (I got mine from a pallet)
-A threaded metal rod
-Wood glue
-Spray paint
-Clear coat
-Spray adhesive
-Leather
The tools I used were:
-Coping saw
-Rasp and files
-Drill
-Electric sander
-Rotary tool
-Scissors
Step 1: Design
To get the look right I grabbed a picture of the sword off the internet, enlarged it to the size I wanted and then printed it out. I just printed the handle part since I figured I could probably do the blade without it.
Once I had the design traced onto the wood I cut it out with a coping saw.
Step 2: Shaping the Handle
To get the rounded look I needed I just went to town with my rasp and files. I slimmed down the grip so the leather grip would be flush with the pommel. I also filed down the end of the handle to fit into the cross guard. Other than that I just rounded everything off.
After I had it shaped the way I wanted I drilled a hole into the end of the handle and through the cross guard. I also used my rotary Dremel to cut a slot into one side of the cross guard for the blade to fit into and a hole on the other side for the handle to fit into.
I got a little ahead of myself drawing the detail on but that's for the next step...
Step 3: Adding the Handle Detail
Looking at the little paper cutouts I used as my original templates I tried to copy, as accurately as possible, the detail on the pommel and cross guard. I used my Dremel and a cutting wheel to carefully cut the design into the wood. I also used some small files for fine tuning.
Step 4: The Blade
The wood I was using was a bit thick for a sword blade so I had to thin it down a bit. Because of the detail at the base of the blade I thinned it down in stages.
I used a hand held electric sander to thin out the blade and bevel the edge
I used a coping saw for the tip.
I used my dremel to cut the base of the blade into a tab to fit into the matching notch in the cross guard.
I used my dremel and a rasp and files to do the detail work.
Step 5: Attaching
To attach the blade together I cut a short length of the threaded rod I had and screwed it through the cross guard and into the blade. I didn't use any glue because I figured the threading would do its job, but I kind of wish I had at least put some glue in the seam before putting it together. I had made the hole in the handle slightly too big because I knew I wouldn't be able to screw that one on since it was going into the cross guard and it wasn't perfectly round. So for that side I put glue all over the rod and jammed it into the handle.
Step 6: Painting
I just used a primer I had around so I was a little worried about the color, but it ended up not mattering. After it was all primed I used a hammered silver spray paint and used light coats so I would get the silver metal look without the hammered look.
After it dried I watered down some black acrylic paint and did a couple coats where I brushed it into the detail, wiped it off, let it dry, repeat, until it looked like I wanted it to.
Step 7: Leather Grip
I wrapped some paper around it to try to get a feel of how the leather would fit and tried to trace the shape of the pommel. Once I cut the leather out I tweaked it a bit more.
I sprayed the back of the leather with a spray adhesive wrapped it around the handle and put a bunch of rubber bands around it.
Step 8: Finish
You're done!
If you want you can add more details. You could weather the blade, or add blood splatter. You can add more features to the grip. Some versions I've seen have a wire wrap design overtop of the leather. You can also stitch the seam in the grip up if you want. I might do that to make it more durable but it's not required.
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
  • Flowers Challenge
    Flowers Challenge
20 Comments
what's the estimated time to make this?
Very good work! Congratulations, friend. Thanks for sharing!
This is the best sword seen yet why don't you enter the wood contest?
Thanks, but it was published long before that contest came along.
I own the sword of altaïr and what you made is so exact you can sell them as replicas
Thanks for the huge compliment!
Ooo, I do like that sword. It's not on my project list as of right now but maybe I should add it. Not sure how I'd do that basket guard though.
You're right, that is a nice sword, but the one i was thinking of was the one in AC4
I think it's the one you get if you get the ezio and altair pack or if you have played ac2 before. Not sure which.
I'll have to look into it. I haven't made it that one yet. I'm way behind.
I was really happy with the way that turned out since the detail itself was so small and I had never done any painting like that before.
Wow!! Looks great!!
Oh this is fantastic!! What a wonderful project!
