3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Swords, Daggers, and Axes
  • last photo ←
Here are just a few of the swords, daggers, and axes i've made over the years. i've always been fascinated by swords and blades of all types. when i was younger i wanted a sword and couldn't afford one so i guess my skills started out with a hacksaw and a file and a piece of steel i found laying around, and have been growing ever since. i'm still working on improving my skills, and would like to learn blacksmithing , and build my own forge one day.
Edit: Molnar Sword instructable is now up here:  http://www.instructables.com/id/Sword-Making-by-Stock-Removal/
47 comments
1-40 of 47next »
Dec 4, 2011. 5:42 AMSabinbp says:
Is it me or does those blades look dull?
Dec 11, 2011. 3:24 PMdidgitalpunk says:
no they do look dull
Nov 25, 2011. 4:54 PMcurvy77 says:
great designs. how do you make these and what materials do u use? plz help a fellow scrapsmith!
Nov 17, 2011. 6:36 PMmr.frob says:
That is some really beautiful work.
Jun 29, 2010. 11:51 AMThe Jamalam says:
I really like the sword in slides 4-7, please make instructions :O
Jul 3, 2010. 4:53 PMthe_burrito_master says:
Awesome i cant wait to see that! I don't have enough steel for it tho :(
Jul 8, 2010. 7:10 PMthe_burrito_master says:
Impressive ,do you melt it down or like forge it into a block and then draw out the swords?
Jul 9, 2010. 5:32 PMthe_burrito_master says:
I see, I don't understand how this steel magically found in your garage lol? Forging is really quite simple, pretty much you heat up the metal red hot and hit it with a hammer.
Jul 10, 2010. 9:58 PMthe_burrito_master says:
Yeah there's definetly more to it than that but it's not ,that complicated... if you just do some research you should figure it out pretty quick, not that I'm any expert. I did a bit of forging on this sword today. I drew out the hilt witch should not haven taken as long as it did but wood just doesn't work with high carbon steel :P
Jul 11, 2010. 11:11 AMthe_burrito_master says:
Well I meant to say that the wood wasn't making hot enough coals for me to gt the steel past dark red, so it was almost just like hitting the solid steel. My handle was pretty easy to make, because I first cut 2 slats from a 11/2 by 1 and then carved out the inside, to fit over the hilt in the drawing. Then I just smoothed out the wood to fit my liking. when you forge it's kind of important to use high carbon steel i bought mine from http://www.admiralsteel.com/ I'm using the 1095 steel witch is impressively strong.
Aug 23, 2011. 11:38 AMninja of suburbia says:
You couldn't heat it up hot enough because you are using the wrong fuel. Go to the hardware store and buy a big sack of lump charcoal, not mesquite, and that should solve the problem.
Sep 11, 2011. 1:10 AMthe_burrito_master says:
I've been using coal and wood lately, the wood is actually the best fuel I've used yet, only because i have an abundance of it. I'm sure charcoal would burn much hotter.
Jul 11, 2010. 12:37 PMthe_burrito_master says:
I'm not gonna secure it in until it's done ll sorry bout that and if I put any tension at all on the handle i cant pull it out for anything.
Jul 11, 2010. 5:38 PMthe_burrito_master says:
thanks :) i would have liked to start out with a box of steel and forge it out jsut liek the japanese do. but a bar works okay. If i did that then I could give it a bit more of an accurate shape.
Jul 10, 2010. 12:47 AMUnderminer says:
Dude I think you have some mad skills as far as sword making goes.
Jul 10, 2010. 12:08 PMUnderminer says:
Think of the stuff that you'll make when you learn to Blacksmith!
Aug 23, 2011. 11:43 AMninja of suburbia says:
Go to an old scrapyard and look around. Old anvils are everywhere, they're just hard to find. Also, you don't have to use an anvil, per se. My master has an anvil that is merely a length of railroad track secured to a stump. It just needs to be big and very very solid. Even a thick steel plate attached to a solid base would work. On another note, use a coal forge. While it is messier and slower than gas, it produces far better quality blades.
Aug 23, 2011. 4:12 PMninja of suburbia says:
If you like, I can post an 'Ible about making a good starter forge, no large scale, but good for smaller knives, arrowheads, hooks, etc. just to get your hand in.
Aug 23, 2011. 11:36 AMninja of suburbia says:
These are some rather well made blades, and even though I believe hand-forging to be superior to stock removal, I congratulate you on work well done.
Apr 28, 2011. 8:23 PMdamascus freak says:
hey man awsome. i just started pretty much the same as u. i used an old bed rail and a jig saw to make a sword, its pretty lame:(
Feb 25, 2011. 2:10 PMThat Inventor Dude says:
Duuuude, that i just awesome,
Sep 19, 2010. 10:18 AMbillyberserker says:
Interesting...
What did you use to make the axe in the end of the slideshow?
Sep 20, 2010. 12:00 PMbillyberserker says:
Nice! Liked the design!
Sep 21, 2010. 12:04 PMbillyberserker says:
I'm expecting a wonderful weapon then. :)
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Deathatsix(My art site at Deviant art)
i'm a person who dosn't believe in "i can't". sometimes you just have to. and when you can't afford it, you just have to make it. needless to say i spend most of my money on tools of all sorts, and s...
more »
