Sypranic 8 round Revolver + Modern by Sypran
Step 4: Lock and load baby!
loading the gun is easy, pull the pin back until it is half way between the grey and red connectors and make the pin stuck by making it push upwards the do the picture instructions.
pic 1) in between the red connector and snowflake insert a white rod (you can load from the other side as well)
pic 2) pull the pin back if you have not already and turn the cylinder until it is a little more then halfway to the next bullet.
and you are ready to fire my friend, turn the cylinder all the way and it will fire.
well thats it, this was brought to you by; Sypran, 2 hours of work to desine and get a frame, 3 bottles of rootbeer, your Internet provider, and last but certainly the best Eric for making this fantastic website!
good bye and happy shooting!
jbreck says: Aug 17, 2011. 3:19 AM
how do you get the revolver to turn
Sypran (author) says: Aug 18, 2011. 7:15 PM
When you pull the firing pin back you can then turn it
ninjaguy25 says: Jul 1, 2009. 9:57 PM
how do u put the rubber bands on?
Sypran (author) says: Jul 2, 2009. 11:10 PM
uhhh, tbh thats where i dont even know... i just put them where ever they could go and not interfear....
runthunter246 says: Mar 31, 2009. 3:27 PM
2.5 star..no trigger. and jams easily. but im making mods to it so that its a 4.5 - 5 *
Sypran (author) says: Mar 31, 2009. 7:00 PM
how does it jam!? the only way for it to jam is if you don't push the ammo all the way it?
runthunter246 says: Mar 31, 2009. 7:06 PM
u have to keep the cylander level or else ammo with fall out and whites dont work for ammo because there is no room for the firing pin to stay in the ammo hole ...but i do give you props for the cylander idea its sweet.
Sypran (author) says: Mar 31, 2009. 8:34 PM
whites don't work!? - ohh well the trick is to bock the pin (prob a external peice then load ammo, then in between chanbers get the pin unblobked, then turn the cylinder and Boom it fires as for the ammo coming out are you sure you followed all instructions like the tape on the yellow conectors holes? as for a trigger like Vs well i never trusted triggers like that since it it is not fully turned it will hit the cylander like a bullet and damage it (had this happen to me second cylinder and it broke)
runthunter246 says: Apr 1, 2009. 3:58 AM
uhh yes i put tape on yellow connectors..helps some..but whites still fall out when u til it up or down..o well ill find a way to make them stay.
Sypran (author) says: Apr 1, 2009. 4:03 PM
where????? did you put green rods on the conectors (except where you load the gun)
runthunter246 says: Mar 31, 2009. 7:07 PM
look at "the VINdicator";s revolver..it uses your cylander idea but it holds the ammo in place and has a black trigger
mrpowerful says: Nov 13, 2008. 4:35 PM
This gun looks cool... but i cant even get it to fire right
uri172 says: Jul 13, 2008. 11:57 AM
hi
Sypran (author) says: Jul 14, 2008. 9:39 AM
hello
nichodo says: Jul 3, 2008. 3:22 PM
your eight round Revolver is really nice! i like it
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
