3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Syringe pump prototype
video Syringe pump prototype
This video demonstrates how to make a simple single or dual syringe pump using an AXE deodorant container (for the linear actuator), a Lego WeDo robotics servo motor and a "Scratch" program to control the servo.  The syringe pump can deliver approximately 200 microliter per step and can run in either "timed mode", full advance, full retract or advance/retract.
The syringes used for this demonstration are 1 ml intra-dermal syringes with 0.1 ml markings.  The needles are very small and are magnified in the video segment to demonstrate the step control feature.
The syringes need not be connected to needles and may be used to deliver fluids to tubing.
WARNING:  This is a Do-it-yourself project.  I am sharing my thoughts and experience, not telling you what this can be used to accomplish.  I will tell you that its not for medical, diagnostic or research uses.  The intriguing part of this process was the flexibility of Scratch program control which enabled configuration of timed delivery and of course the use of a deodorant container (which should make the bit about NO research use kind of obvious).
5 comments
Mar 14, 2012. 2:58 PMbatman96 says:
I imagine a Glue stick screw could be used also for the linear actuator.
Just a tip for anyone who wants to build one and doesn't have an empty deodorant.
Jan 12, 2012. 6:32 AMblorgggg says:
nice!
Jan 27, 2011. 9:30 PMaeray says:
Nope, no video.
Jan 27, 2011. 5:51 PMtemper says:
er... where's the video?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:siderits
