T-shirt to sexy top
Step 2The lower part
The lower part
Measure the circumference of your chest.
Cut a piece of elastic that matches your measurements.
Turn the shirt inside out and cut a small opening on the bottom hem.
Use a safety pin to attach one end of the elastic and insert the pin through the small opening. Pass the safety pin (and the elastic) inside the hem until you reach the other end.
Attach the two ends of the elastic by sewing them.
Turn the shirt right side out. Now it should look like the picture.
1 comment
Jun 26, 2011. 7:35 PMhahahippo=) says:
"a piece of elastic that matches your measurements." would be about one inch less then your original measurement, to keep it snug. If you want it tighter, adjust as needed. Also, (this is a no brainer, but I am saying it anyways) a good way to see the length of the elastic is to hold it up around yourself where it will be then put a mark there. But leave extra just in case!!! Hope this helps!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
48
Author:diana.cristea
