TESLA FREE ENERGY GENERATOR (COLLECTOR)
92,755
283
53
Published
Introduction: TESLA FREE ENERGY GENERATOR (COLLECTOR)
About: Hello My name is Prayag Nao.I am a tech enthusiastic person who does not follow reality,instead I create reality.I am sharing some project with you.I hope you will like them.
Hello friends you hv also heard about tesla who was great inventor.i m going to make his device for collecting energy from air.for make this device you will need these things....
1. 4 diodes
2. a 100uf ,50v capacitor
3. aluminum foil
4. piece of card board
5. some wires
6.LED(optional)
Step 1: Antenna Making
Get a piece of cardboard and take aluminum foil the size of ur cardboard and staple foil on cardboard then hang it in room or go outdoor and put it on a pole at least 9-10 feet off the ground.Now take a wire and connect its one end to anteena
Step 2: GROUNDING CONNECTION
its is easy to make if u can go outdoor then take a metal rod and take another wire and connect one end of wire to rod and stick rod in the ground.
Step 3: MAKING DEVICE
make circuit according to give figure.i make my circuit on bread board.You can use any type of capacitor as high uf you can,i used 100uf,50v capacitor.after completing your circuit as shown in figure  get 1-2 volts in 10-15 min.i got 13.56 volts in 4 hours.my charging rate was very slow bcz i placed my antenna in my room only few centimeters above the ground.i am able to run a LED for 40-50 sec.
Step 4: THEORY OF OPERATION
as we know in normal days air content free positive charge and ground content negative charge.when we put antenna or any metallic object in air it gains positive polarity.in this project we are making aluminum foil positive and metal rod negative.when we connect a capacitor b\w them capacitor get charged.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    Hi, nice project!
    How many of this generator I'll need to charge my mobile phone?
    53 Comments
    this uses radio waves . Natural or artificial it doesn't matter. If it collected dc charges from the air it wouldn't need a rectifier. Radio waves create ac between an antenna and a ground connection, so it needs a rectifier. It is a cool project but if you tried to power your house with it you'd get in trouble for stealing everybody's radio signals.
    I have 100 uf 400vlt capacity is it ok ?
    pls am currently working on this device as a school project, can anyone pls send me a write up for this? pls and pls
    Did you finish your project .
    Those that think that this works by picking up radio waves, seem to forget that in 1901 when Telsa patiented the device, there were no radio waves being transmitted. At that time to have a patient approved, a working device had to be presented to the patient examiner so it worked then with no radio waves.
    I am sorry, but radio waves were there already at the very beginning of the universe !
    We are completely surrounded by radio waves. Light, visible or not, is also a radio wave !
    True, but I am talking about man produced radio waves, many seem to believe that this is what is powering the device, I was only pointing out that this is not the case. Maybe I didn't make myself clear enough.
    No light is not a radio wave. Light is a wave yes but radio waves are much higher frequency. They are on another part of the electromagnetic spectrum.
    Light is electromagnetic wave with much higher frequency than radio waves
    (light is in THz range, where radio waves are in kHz-MHz range)
    we are also surrounded by cosmic rays
    I think it`s Better Tech ??? I try it.
    What is the purpose of the diodes? Could you not just connect the antennae to once side of the capacitor and grouond to the other?
    Diode converts AC into DC
    Can I use IN4007 RECTIFIER DIODE. OR SEVERAL MODULE FOR HIGHER VOLTAGE & CURRENT.
    THANK ALL.
    Good Question. Can you use the 1N4007 diodes AND a larger cap?
    Does anyone have a schematic for a pulse charger, once the cap has reached a preset voltage it would discharge into a charging circuit?
    Sir Norman
    Hi, I made your circuit and put it up on 11-13-16. 10 ft pvc pole and a small part from an old tv ant. that I had. After 20 min. voltage went from o vdc to.374 vdc. After 90 min. the voltage went to .763 vdc. Today I checked itat 7:05 am it was at 6.26 vdc. At 11:am it was at4.58 vdc . Do you possible know why this happened. Its now 1:pm and its at 5.27 vdc. Thanks bud man
    can i use the steel roof of my house as an ariel and the ground post as an earth to make a kick-arse battery charger that will power the LED lighting of my house at night?
    Hi! Just want to ask what would be the effect on the circuitry if I use silicon diodes?instead of germanium diodes? Thanks in advance.
    http://free-energy-info.com/Chapter7.pdf Looking at pages 12 and 13 of chapter seven shows that the circuits can be stacked to make enough power for recharging batteries.
