loading
Step 14: Joining the Barrel Assembly and Ammo Barrel Step 1
Now all the minigun needs is its rear handle and to be put together.
Putting it all together is actually simpler than it sounds. The ammo barrel and the gun barrel just need to be bolted together.
Start by cutting a length of the 1/8" steel, I would say around six inches or so. Drill a 5/16" hole near one end (and yes, I would buy a bit for this, I did in the end, dremeling out a 1/4" hole to 5/16" in steel plate is not fun) and put it on the right side of the 5/16" threaded rod that the handle assembly attaches to.
Bolt it in place and position the ammo barrel where you want it to go. Keep in mind that at least some of it needs to be in a straight line under the middle of the barrel (for the rear connection point of the rear handle) and it needs to be far back enough that the third connection point between the barrel assembly and the ammo barrel can be made, however it should still be slightly off center to the right of the barrel assembly. The description is a bit awkward but the pictures of my build and the source images you should have studied will hopefully help it make more sense.
Mark on the ammo barrel where the piece of steel intersects with it and, using a dremel, cut a slot for the steel. Slide the barrel down on the steel until it is the proper distance from the barrel assembly, this is also fairly subjective but mine is around 2 1/2" beneath the barrel assembly.
Mark the point at which the steel meets the barrel then drill a hole on either side, fit the steel back into the barrel and put a bolt through both holes to hold the barrel in place.
Your costume is flawless, except that you don't have a sandvich (bet you are TIRED of hearing that).<br>So here's another idea: replicate the new eatable-The Dalokah's Bar-by buying a hershey's bar. Simpler, more effective, and moar delicious. :3
Paciface is credit to instructables! (by the way, where is your&nbsp;Sandvich?)
<p>Where did you get that sweater? It looks awesome!</p>
I will most definitely pay you to make me one of these
You sir, are a hero.
Pwnlock, not to criticize, LOL, but he mentions in his narrative that he knew there should be six barrels, but the limit of the part only allowed five. :)
Not to criticize, but there are 6 rods in the barrel. Not 5.
oooooh they gonna have to glue you back together, in hell!
WHAT seeck man sends BABIES to fight?!
&nbsp;WHO TOUCHES SASHA!?!?
actually its &quot;WHO&nbsp;TOUCHED&nbsp;MY&nbsp;NATASHCA!?!?!?!?!?!&quot;
WRONG!!!! it goes &quot;WHO TOUCHED MY GUN?!?!?!?!&quot;
your all wrong its omg who touched sasha , WHO TOUCHED MY GUN!?!
it actually is sasha, listen to the meet the heavy thing, he says sasha&nbsp;
Oh yeah, the video I&nbsp;was watching said in the 'lyrics' in the description that he said Natashca. I prefer Natashca.
MY FISTS -- THEY ARE MADE OF STEEL!!
You forgot the sandwich, the most important part of the heavy.
Love the Gatling gun! I would combine 2 of those with a version of the <a href="https://www.instructables.com/id/Life-Size-Power-Loader-Costume-from-Aliens/">Powerloader</a>&nbsp;costume and make the Wolverine from Command &amp; Conquer: Tiberian Sun!
i dont think the heavy wears sandals
Yeah, in San Francisco he does.<br />
does sandvich where sandals?
YOU NEED A SANDVICH
I don't think the heavy wears birkenstocks and baggy jeans. You my friend should move out of your parents basement and get a life. I like the minigun though, if only it shot real bullets
CRY&nbsp;SOME&nbsp;MOAR&nbsp;XD<br />
it cost 400,000 dollars to build this coustume... in twelve seconds
hay, I did a very similar thing which cost me about 20 bucks and took only 2 hours to make. it was probably cos my minigun was made of cardboard. whats with the hat? it sort of spoils the costume<br />
The hat is a Russian Ushanka, and it is in the game.<br />
oh yeah soz, I just unlocked it... dont play heavy v. much, I prefer spys, scouts, and snipers.
Ammo barrel? It's called a drum magazine. Other than that exelent prop. Have to remember to construct one for LARP use<br />
wow nice gun, havent played t2f though.
It's TF2, not t2f. It stands for team fortress 2
i know what it means.......
Meh...
hehe sweeeeeeeeeeeet!
Nice ushanka. 5/5<br />
Ammo barrel? It's a propane tank...<br />
It's a ammo container like those on 'tommy guns.'<br />
Why would it be a propane tank?&nbsp;The thing attached to the pyro's flamethrower is obviously a propane tank and that makes sense, but since this has a chute on it that spits spent cartridges and is attached to a giant gun instead of a flamethrower it would make sense that it's where the ammo is held, don't you think?<br />
now all it needs is a paintball gun hidden in the ammo barrel, with the barrel of the paintball gun in the top barrel of the &quot;fake&quot;&nbsp;gun. like a paintball gatling gun!!
The only problem with that is that in most places a paintball gun is considered a firearm and carrying something like this with a hidden firearm inside could, conceivably, get you into trouble.<br /><br />Personally I'd rather not get shot over my Halloween costume.<br />
Awesome project, cant wait for finished photos !!<br />
complete it first then post it up..<br />
My thought was it's a complicated project and the only thing that's missing are some painting shots, a few finishing detail steps, and pictures of it all put together.<br /><br />At this point anyone so inclined could follow the directions and complete a satisfactory costume, and since it is rather time consuming posting it now (when it's complete enough that someone who would like to could follow the steps to build their own) gives anyone who would like to use this for Halloween enough time to build their own.<br /><br />Sorry if it offends you horrifically that you'll have to wait a couple days for the final shots, but if you want to know what it would look like that badly you can always build your own. Everything you need is already here.<br />
NeeeeAAAAHHhh....where's the last pic!? it looks like it'll be awesome! LETS SEE IT!!!
It's coming, just be patient. I'm actually working on it as we speak and hope to have it done by the end of this coming weekend.
Definitely needs a completed shot. Then it can be featured for sure.<br />
<em>&quot;work in progress&quot;</em><br/>
About This Instructable
56,355views
67favorites
License:
More by pacifcace:TF2 Heavy Weapons Guy Costume
Add instructable to:
