Introduction: THE CROSSBOW!!!
Hi, I am here to tell you how to make a easy Instructable. This is one I hope everyone will like. So please rate. There have been others that are about the same but it seems like all the other ones that I have made the ruberband comes off. So this is one that it dose not come off.
Step 1: Geting the Things.
The things you need are:
2 straws
2 skewers
glue and tape.
Step 2: Cuting the Straw.
First you bend the straw about 1.5 inches from the end. Then cut each corner like in the pic.
Step 3:
Get your skewer and cut it at 5 inches.
Step 4:
So, now you need to put the piece of skewer threw the hole in the straw. Like in the pic. Then you glue theme together.And tape them.
Step 5:
In this step you are going to put the other straw on. You put it underneath the first straw. Like in the pic. And then you tape it. Or glue it. I taped it.
Step 6:
OK, now your going to make a slit with the scissors in the skewer. On both sides. And then you cut the ruberband. Then put the end of the ruberband in the slit. On both sides. And then tie the ends together.  When  your done with that you can rap tape around the end. So it holds better.
Step 7: Shooting It.
Get your other skewer and if you want to be safe cut off the end which I recommend. And your done. And go fire away.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    You say "please rate" but Instructables has no rating system.
