3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
THE TYPES OF POTATO CANNONS
 there are two types of potato cannons. combustion and air.
DISCLAIMER
we at lightning works will not be held responsible for any actions or events that occur as a result of any publications of any kind, that come from our company. once a person has viewed our information, we are not responsible for there actions
also, these things can kill you
Step 1COMBUSTION CANNON
COMBUSTION CANNON
 The first type the combustion cannon.
it uses a gas, an ignition source, and a compressed area to launch projectiles
31 comments
Oct 31, 2011. 8:42 PMramicaza says:
2 things.
electric actuation is not more powerful. Blowgun is because it opens MUCH faster and has higher flow.
Also, you forgot hybrids. Other than that, great instructable
Feb 7, 2010. 2:30 PMdrumerdude250 says:
It doesnt matter usually about the chamber size unless you have a really long barrel, the bigger chambers just take longer to fill up
Feb 14, 2011. 3:24 PMjj.inc says:
I have one that launches water filled 700mL pop bottles over 400 feet, its not loud and has a chamber almost twice as big as yours, your neighbors must have their hearing aids up too loud.
Feb 14, 2011. 6:11 PMjj.inc says:
Yea here is my instrucable: http://www.instructables.com/id/Multi-Barrel-Air-Gunpaint-ball-tennis-ball-pota/
Ok, I also wondered about the small valve causing performance loss, so if you make it bigger it will help. I didn't realize you had a 5 inch tank, I though it was 3, mine is 4 inch so I guess they are about the same size.
I also realized my 3/4inch paint-ball barrel is really loud.
Feb 15, 2011. 2:03 PMjj.inc says:
Where do you get 5 inch pvc?
Feb 16, 2011. 4:33 PMjj.inc says:
I guessed so. Your lucky for your combustion gun, I am not allowed to have one.
Feb 16, 2011. 7:27 PMjj.inc says:
Thats hard to imagine, what do you use for fuel, I am thinking propane
Feb 20, 2011. 8:02 PMjj.inc says:
I am not sure on the movie, when you say doesn't work, does it just not ignite, or does it not have enough power. Propane, and butane are both heavier than air so getting it to mix in the chamber can be hard without a fan. Gasoline and starter fluid you would have to vigorously shake the gun for about a minute and only use like a half tablespoon of it. For AXE and Lysol, if you hold them both upside down then one probably is full of gas, and the other liquid. One dispense the liquid, which would most likely be the AXE, and the other would dispense the gas aerosol mix. If your holding them right-side up, then they probably have straws, I have used Lysol for a flame throwing setup, both the aerosol and air freshener air combustible because if you spray it on a paper towel it burns up almost instantly.
Feb 21, 2011. 3:44 PMjj.inc says:
Try finding some canned oxygen, it will give your combustion a huge boost, they are at sports stores and I actually saw some this weekend at a ski rental store. You can also try nitrous oxide canisters for whipped cream. I wonder if you just don't have a large enough spark, you could try a butane lighter to start it.
Mar 12, 2011. 8:16 PMjj.inc says:
I don't know if you care anymore but I found out why Lysol works. It is a germ killer which means it probably contains alcohol which is very flammable and easy to ignite.
Mar 14, 2011. 8:35 PMjj.inc says:
My guess is that they are just harder to ignite, butane for sure is especially hard to mix with the air in you combustion chamber. If you had a good 1/2 inch spark I am sure anything would go off but that isn't easy to get. I think it would just be easiest to use the Lysol.
By the way, do you air it out after every shot.
Mar 15, 2011. 5:00 PMjj.inc says:
that doesn't sound good, I was cutting pvc pipe in half, then realized it was toxic, I have finally gotten over my cough although they might not be related.
Feb 15, 2011. 2:02 PMjj.inc says:
yea, I have had a much smaller chamber before, but I like this one much better because it always has more than enough, which doesn't but me because it fills up in 2 seconds +/- 1.
Apr 19, 2010. 5:07 PMpyrofire says:
HOLY CRAP, 1000 feet .  And at less than 1/3 the possible pressure.  That is great.
Feb 26, 2010. 8:46 PMKahlZun says:
Does freezing the potato make a difference to impact?
Someone told me once that a frozen potato in a spud cannon can go right through a car door...
..Anyone know if they're right?
Feb 15, 2010. 9:54 PMTheFawns says:
Im making one of these :)
Dec 2, 2009. 4:16 PMtoogers says:
you forgot one kind, a hybrid cannon. it uses compressed air and ignitor+fuel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:monkhm
