Introduction: T.K.B.T (The Knex Bear Trap)
Check My Tornado 480 Command V2 too!
This is my latest creation and actaully a very simple one.
Basically, the claw grabs something that hits the blue rod and it just puts it's teeth into it... and hard!
Pros:
-strong
-fun to use
-can trap anything (even my walking-robot)
-a chain so the target can't move
-it keeps it's mouth closed when hit
Cons
-might bite and close when you're setting it
For short:
It's a recommandable Bear Trap.
Update on the Tornado:
It is Posted!!!
Step 1: The Ring
This part is for a sturdy bodyframe.
Step 2: The Pole Ring
This part is to lock it around something like a tree.
Step 3: The Chain
this part is to keep the Trap Ring and the Pole Ring together.
Step 4: The Emplacer
This part is to keep the trap opened until someone or something hits it.
Step 5: The Actual Trap
the Rings and the Chain are actually not required (but they make it look nicer), you only need the actual Trap and the Emplacer.
Step 6: Assembly
The pictures speak for themselves:
If you have any problems, post a comment on my orangeboard.
Step 7: The Tricky Bit
This part is kinda tricky and will require some stable fingers.
you need to disconnect the yellow rods so the trap is set.
here, 2 pics on how it should look.
pic 1 connected, pic 2 disconnected.
Step 8: It's Done!!!!
Weel you've built yourself a knex bear trap.
have freaking much fun!!!
176 Comments
yes
yes
MAHAHAHAHAAHHA
can I use the orange double sided things instead of those one side grey things I have only orange I don't have anymore grey
How many of these pieces?
That a good idea !!
I will build it AWSOME!!!!
nice
Thanks mate.
Are you acting brittish??????
In the emplacer step does the blue rod with the grey clip attached to anything underneath???
Easy to deactivate, like all bear traps. Someone throws something on it, it snaps shut and is deactivated.
And that's a bad thing?
