TRANSFORMATION LEGGING & TANK TOP INTO JUMPSUIT
2,867
16
Published
Introduction: TRANSFORMATION LEGGING & TANK TOP INTO JUMPSUIT
About: Im a Youtuber & blogger from Amsterdam. I like to make things :D
You will need:
legging
tank top
scissors
sewing machine
pins
Step 1:
Put the top inside the legging then pull the legging up till desired height.
Once your happy, mark the height with a pin.
Tip: Its better to wear the top inside out.
Step 2:
Cut the extra fabric off. Don't forget about your seam allowance.
Optional: Draw stichting line with a chalk on the inside of the top.
Step 3:
I removed the elastic to get more length, so I could get the height that I wanted. This step is time consuming and it also depends how high waisted you want your jumpsuit to be.
You can skip this step if you want too.
Step 4:
Turn your top inside out and place it over the legging. Then pin them together and sew all the way around with a straight or a zig-zag stitch.
Make sure to stretch the fabric when you sew.
Step 5:
Cut off the extra seam allowance if you have and lastly serge the edge
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
