PARTS LIST
rods
-101 green rods
-54 white rods
-20 blue rods
-10 yellow rods
-4 black/gray long rods
connectors
-42 yellow connectors
-2 green connectors
-6 gray 2 connectors
-54 gray single connectors
-20 orange connectors
-2 tan rod connectors
-38 white connectors
-3 blue connectors
-42 black Y connectors (i used alot of these as spacers so u probably don't need all of these)
-5 red connectors
-10 black U joint connectors
spacers
-11 blue spacers
-4 gray spacers
TOTAL
435
MY KNEX HAND GUN REVOLVER
http://www.instructables.com/id/8-SHOT-KNEX-HAND-GUN-REVOLVER/
MY 12 SHOT KNEX GUN
http://www.instructables.com/id/extreme_builders_12_shot_knex_gun/
hey everyone,
check out my youtube page
http://www.youtube.com/user/KNEmovies
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
i only wanted to make the fireing mech and i am 8 white connectors short!
aldhfladhflajdhlfhaltd! raaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaah!
Because I'm only building this if Extreme Builder hasn't lied to us all.
Btw, plz look at the date before posting. That was 2 years ago. ;-)
just kidding. no offense great gun! its kewl!
if you put string between the pullback mech and the pin, you could pull back the pin farther, generating more power. i would try, but i havent got the time.
i realise you probably dont have the gun anymore, but maybe post in instructions??
=D
how 2 make it more powerful: #1 make ur firingpin stik out of the barrel #2 smaller bullets #3.... well its to hard 2 say with a keyboard....
thanks for the help im stuk on one!
i have enough pieces - yes
boring to build stock after SRV1 - Hell Yes!
http://www.instructables.com/id/Knex_Tavor_TAR_21/
This is a nice assault rifle that I have made. I am not completely finished, but will be posting pretty soon.
FEATURES:
*It has an adjustable stock.
*It has an adjustable handle (it thickens and shrinks for different age use)
*It has a slide-in magazine. The magazine slides into place. You don't have to snap it on any rod or anything like that. It just slides in.
*It is semi-auto. (This is my own original semi-auto design. I did not copy extreme builder.) But because it is semi-auto, it only shoots a couple feet.
*It has a scope.
*It has a comfortable grip.
*AND MORE
Please PM me if you want me to post:
Try moding the design to use Perfect Duck's
frictionless spring recoil design so the firing rod
doesn't have to move much and still provide power.
The design can be seen here:
http://www.instructables.com/id/Red-Impact---Perfect-Duck_s-K_nex-gun./
Semi auto = every time you pull the trigger it fires untill out of bullets (exeption things with real hammers like revolvers this is called "Double action")
Bolt action = pull a bolt back, then may have magazine that auto loads or be a 1 shot. (most knex guns are this)
Pump+leaver = same as bolt but diffrent motions
"Mind auto" = experimental (at the momemt) that you have a gun and when you point and think to fire, it fires (like how you controll your arms), - this system has been failing though, untill they make a smart gun, because it has caused "reflex shots" on allies and thats never good i would think.
(passes out)
lol
I love how you're completely unafraid to use rubber bands wherever necessary. You've got them balanced just right to make the operation of this gun simple and effective. So, with a 10/10 for operation, its actual performance leaves much to be desired. Only 6-7 round capacity and weak power ... that's fine, though. The fact it works is good enough for a technology bed after all.
It's hard to say how much potential this has, as far as the kinds of improvements on it that you're hoping for. There's only so far of distance that the lever can actually pull the firing pin, so getting it to accelerate to competitive speeds will be difficult. Giving it another hopper with a larger ammo capacity would be simple enough, though.
In closing, I found it very interesting and hope to see more guns that are as simple to operate as this one.
