So I fixed SF40 SuperFOIL to the underside of my rafters to keep warm, cut bills and save the planet: www.superfoil.co.uk/SF40-titlepage.html
I chose SF40 because:
a) It nails to the roof, so you can still use the loft for storage
b) It has a radiant heat barrier
c) It is the equivalent of fitting 450mm (18 inches) depth of fibreglass*
d) It should keep us cool in summer too
I expect there are other products you could use, but this one seemed right for us.
There are a lot of steps to this instructable, but it's not as complex as all that. I waste a lot of time talking about nailguns and such. You can skip to step 16 if you want.
NB: Apparently what we Brits call a loft is what our Yankee cousins call an attic. For them this 'ible is about attics.
* Clarification: fibreglass does not block radiant heat; the quilt does. In order to get the same savings, you would have to install 18" of fibreglass. But this does NOT mean that the R values are the same. See the manufacturer's brochure illustrated in the second pic of step 3.
Remove these ads by
Signing UpStep 1And here it is
You can use insulating boards; but they don't give the same insulation value, and you can't cut them with a pair of scissors.
Have you actually READ this Instructable?
1. I have clearly stated the savings we have already made, and the payback period.
2. Why insulate a non-living space...? In the text I have clearly described the benefits and the reasons for installing the quilt. You are arguing in favour of a 'cold loft' , but for reasons I have explained I opted for a warm one (cold water tank in loft BTW).
Anyone who wishes to check the benefits of each can google 'cold loft'.
3. I have no icicles forming on my roof.
4. The loft floor IS insulated - as described. The loft access door IS stripped and insulated. The soffits ARE ventilated.
I have no idea what you are talking about with icicles - I have never mentioned them.
I have had numerous positive comments on this 'ible.
Can I suggest that rather than rubbishing someone else's instructable you spend the time writing one of your own?
However, you have made it clear there are numerous reasons for you to heat your attic, so don't worry about it.
You may have a situation something like this with no air flow: http://www.nylumber.com/images/ice2.JPG
What you want to do is add those styrofoam spacers (raft-r-mate polystyrene attic rafter vents): http://roofing.owenscorning.com/homeowner/accessories/ventilation/raftrmate.aspx
Best check with the manufacturers. Someone here has recommended:
www.eshield.net
and they look OK to me.
You are in the right of it: my attic (we use that word interchangeably) has floorboards in it - as explained in step 5.
The title of my 'ible has been amended accordingly.
Attic: mainly an UNLIVABLE space at the top of your house; has roof trusses throughout the support the roof, so you can't really put a 'livable' space up there; insulation along FLOOR of attic keeps building heat inside (http://www.arrow-insulation.com/img/photos/beforeandafter/large/attic_insulation_after_3.jpg)
Loft: a LIVABLE space where the roof trusses are placed more off to the side in such a way to provide a livable space in between; the insulation is placed along the ROOF/WALLS of the loft; thus there may be no true 'attic' space above (http://i37.tinypic.com/ax1da1.jpg)
I guess my question was just getting to the idea that by installing this on the roof of an ATTIC which already has insulation on the floor would kind of be defeating the blown in floor insulation. Then the heat would be trapped within the metal blanket and blown in insulation, leading to problems.
Also, yes, it's absolutely critical to maintain an airspace between the roof proper (like the plywood) and insulation from the soffit at the bottom of the roof up to the space where the ridge vent is:
http://www.inspectapedia.com/BestPractices/Figure2-57s.jpg
http://www.nachi.org/images10/ridge-vent-baffles.jpg
http://education.nachi.org/images/upload/soffit-ridge_vent.jpg
I'm not a contractor or roofer or insulation specialist or anything, so please excuse me if I say something stupid, but aren't you assuming there's a ridge and soffit vent system? Not every building has them. I know my house doesn't have either. It's got an old-style rotary attic vent, but no soffit vents. My house was built between 1946 and 1949. There are plenty of other buildings around of a similar age that might not have a modern vent setup. Would they still need the airgap between the roof decking and the insulation?
It is ALWAYS a bad idea to punch staples through power cables. Caveat emptor.
Also you may have an evaporative cooler, they require power.
Houses also have power in strange places, thankfully with our house it was back in the age when people didn't really trust the wire that was carrying their juice, so said wire was encased in steel tubing which was properly grounded. Incase of a fault, it would short to the metal pipe and trip the breaker (failing that, the fuse on the power line)
Of course, they may have made a mistake!
