Remove these ads by
Signing UpStep 1What you need...
The circuit parts:
1. Small circuit board
2. (1) 10k variable resistor
3. (1) 555 Timer
4. (4) resistors. 470ohm, 1k, 560ohm
5. (2) high speed switching diodes 1N4148
6. (1) transistor - BC557
7. (2) Infrared LED's
8. (2) 10nf capacitors
9. (1) 9 volt battery
Build the circuit based on the diagram below.
2-after that the collector current is 1 mA "check whit multimeter or data sheet" and it's not enough for turn on a infrared led it shod be 50 mA at least!!!
3-you shod apply voltage to only one pin of transistor...in these circuit you apply voltage on both bass and emitter!!!
all these are wrong in electronic theories so....
COULD YOU PLEASE ANSWER MY 3 QUESTION AND DO NOT REMOVE THEM AGAIN FROM YOUR SITE???
i build these circuit whit pcb and it dosen't work!
when you push a button on tv remote you can see LED's light whit mobile camera on top of the tv remote... it show's that LED work ...but in these circuit not?!
Thanks.
http://www.simple-electronics.com/2011/09/tv-remote-jammer.html
http://www.halted.com/commerce/catalog/spcategory.jsp;jsessionid=BD906DB46CE24400663B07230F9C0CA2?category_id=1122&czuid=1270689974389
I go there physically. Its located near my house so i dont have to pay shipping
"Raspberry!..."
SPACEBALLS!!!!
how could I get a longer range? the one I've built only works when I bring it close to the tv..
though everyone should realize it from the 4 resistors.
Really nice prank BTW. ty
I tried the project and it's great !!!!!! :)
But I was wondering why not just add a switch on the remote's IR LEDs in series instead of making a jammer circuit that would take some time.
would i need a microprocessor or Ardunio or could i make it homemade
