3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
TV Remote Jammer!
TV Remote Jammer!
I've had a few scuffles in my house over the TV remote so I decided to do something about it. I built a circuit that will block my TV and any device I choose from getting a signal from the normal remote control. I turn an ordinary remote into a jammer and the remote still works normally! Watch the video to see it work.
Step 1What you need...
What you need...
I chose to use a Sony remote control (SR-P30) because it has plenty of room inside to add my circuit and a 9 volt battery while keeping the remote fully functional.
The circuit parts:
1. Small circuit board
2. (1) 10k variable resistor
3. (1) 555 Timer
4. (4) resistors. 470ohm, 1k, 560ohm
5. (2) high speed switching diodes 1N4148
6. (1) transistor - BC557
7. (2) Infrared LED's
8. (2) 10nf capacitors
9. (1) 9 volt battery
Build the circuit based on the diagram below.
249 comments
1-40 of 249next »
Apr 1, 2008. 9:37 AMewilhelm says:
Aug 29, 2008. 6:43 AMthepaul1993 says:
cool
Apr 17, 2012. 7:09 PMHiggs Boson says:
This is awesome. But my sister figured out what I was doing, and would not let me continue to hold the remote up. I am going to try and add more infrared LEDs so that it doesn't need to be aimed as precisely and looks less suspicious.
Mar 30, 2012. 1:30 PMhbhb says:
1-these circuit design is something really stupid becuse your Power supply is 9v and diode's turn on in 1v together "two diode" they need 2v so that means voltage applied on output of 555 timer!!!
2-after that the collector current is 1 mA "check whit multimeter or data sheet" and it's not enough for turn on a infrared led it shod be 50 mA at least!!!
3-you shod apply voltage to only one pin of transistor...in these circuit you apply voltage on both bass and emitter!!!
all these are wrong in electronic theories so....
COULD YOU PLEASE ANSWER MY 3 QUESTION AND DO NOT REMOVE THEM AGAIN FROM YOUR SITE???
Mar 25, 2012. 8:20 PMILOVEPONIES!!!!! says:
Kip you forgot the 180ohm resistor in the "What you need" section
Mar 28, 2012. 1:50 PMhbhb says:
when some one say's " i use pcb " that means 180ohm resistor cant be forgotten?!
Feb 24, 2012. 4:50 AMh b says:
hi
i build these circuit whit pcb and it dosen't work!
when you push a button on tv remote you can see LED's light whit mobile camera on top of the tv remote... it show's that LED work ...but in these circuit not?!
Aug 29, 2011. 10:34 PMsneitzke38 says:
What 555 chips could I use I am using the 555CN (from radio shack) and my circuit is not working I have it on breadboard right now and am not sure what isn't working
Thanks.
Nov 13, 2011. 4:48 PMplanetroverrobo says:
I have it on a breadboard to with a 555CN and is not working etheir. Did you get your fixed and if you did can you tell me how you did yours?
Oct 4, 2011. 8:29 AMhighvoltageguy says:
if you like epoxy then use loctite epoxy works like magic
Sep 14, 2011. 11:34 PMmarkee2 says:
got similar circuit schematic but fewer parts. dont know if this one works or not. Or which one is better..   circuit copied from
http://www.simple-electronics.com/2011/09/tv-remote-jammer.html
Jan 16, 2010. 8:54 AMcdousley says:
could i use a diffrent tranistor i cant get this one
Aug 18, 2011. 8:35 PMrobot1398 says:
yes, but it should be PNP
Jan 23, 2010. 1:34 AMsapc says:
can you use a different pot value cause a 10k $9.00 here
Aug 18, 2011. 8:34 PMrobot1398 says:
only 10 inr in india
Apr 7, 2010. 6:26 PMhyudryu says:
It only costs around 2$ at my store. They sell a LOT of stuff.
http://www.halted.com/commerce/catalog/spcategory.jsp;jsessionid=BD906DB46CE24400663B07230F9C0CA2?category_id=1122&czuid=1270689974389
I go there physically. Its located near my house so i dont have to pay shipping
Jul 7, 2011. 5:25 AMroy1931 says:
"We've been jammed sir!"
"Raspberry!..."
SPACEBALLS!!!!
Jul 27, 2011. 10:07 AMmwagner63 says:
Only one man would dare give me the raspberry! LONESTAR!!!!!!!
Jun 30, 2011. 5:52 AMshalu38 says:
can anyone plz specify abt the sign of the capacitor
Jun 18, 2011. 12:24 PMAgentClank says:
where does the 9v negative connect to? and why is there a GND at the bottom?
May 1, 2011. 8:12 AMbkaspersky says:
would these work? http://www.cricklewoodelectronics.com/Cricklewood/product.php?productid=20865&cat=0&page=1
May 1, 2011. 1:37 PMbkaspersky says:
help?
Jun 3, 2009. 4:15 PMB.F.L.M says:
How do yo adjust the frequency??????
Apr 24, 2011. 10:49 PMtledgerwood says:
you can adust the frequency by adjusting the preset (variable ressistor)
Apr 7, 2010. 3:11 PMluudvig says:
how could I get a longer range? the one I've built only works when I bring it close to the tv..
Apr 24, 2011. 10:27 PMtledgerwood says:
you can use tin foil to make a "reflector". Just place behind the LEDs in a three- wall configureation (or a U) and it should up the range if you point it at the set and remove any obstructing materials can't do too much harm. be careful not to short the LEDs out and g-luck!
Apr 2, 2011. 3:46 AMArcagelinos says:
The other remote controls IR leds make a stronger signal at that the ones on this circuit
Apr 7, 2010. 6:27 PMhyudryu says:
Use HIGH powered IR leds or use IR leds and IR laser of low power
Apr 2, 2011. 3:44 AMArcagelinos says:
Kipkay you forgot to put on the resistors the 180ohm resistor
though everyone should realize it from the 4 resistors.
Really nice prank BTW. ty
Apr 7, 2010. 7:32 PMhyudryu says:
Too bad i dont have a oscilloscope Or i would know if it works. I tried it with a visible LED and it just turns on. I will try using a speaker and see what i get later...
Apr 2, 2011. 3:28 AMArcagelinos says:
It just turns on because our eyes cant see its flicker.
Mar 14, 2011. 1:37 PMBruno153 says:
There's a video from Howcast showing how to make this same project.... i wonder why....
Dec 21, 2010. 3:36 PMAirsoft 007 Sniper says:
yo kipkay ive watch loads of your videos but this one is not always a good idea my tv and im sure plenty others have buttons on the front
Sep 27, 2010. 6:16 PMmatstermind says:
lasertag use?
May 27, 2010. 6:56 AMASCAS says:
Hi ! I like your projects and makemagazine.
I tried the project and it's great !!!!!!     :)
But I was wondering why not just add a switch on the remote's IR LEDs in series instead of making a jammer circuit that would take some time.
because a jammer has many other uses too
Mar 21, 2010. 9:12 AMPaladinsfo says:
Oh NUTS! dunno worry about ones and zeros or weird pot adjustments...just wire up and exclusive OR/Modulo two adder and a shift register to get a pseudo random sequence going...three chips will five over 8 million 388 thousand possible combination's for someone to look at.
Feb 5, 2010. 8:16 PMcdousley says:
could someone help me i got an idea if you could make a circuit that cycled through diffrent resistance values to replace the pot it jam jam out a lot of stuff
would i need a microprocessor or Ardunio or could i make it homemade
Aug 4, 2009. 3:19 PMcdousley says:
can i use any 555 timer i con get tlc555 or lm555 will one of those work
Nov 13, 2009. 6:46 PMXellers says:
Yes.
1-40 of 249next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2400
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
