3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
TYE-DYE made with sharpies
Tye-dye is often messy, but neat to look at. Why should you have to deal with the mess when you can do with a few cool sharpies, some rubbing alcohol, and of course something to tie-dye. It takes about 15 minutes to make, and another 15 or so to dry.
Step 1Get your materials
Get your materials
For this craft you will need at least two sharpies (they come in a LOT of cool colors now), a lot of rubber bands, a couple of tennis balls or a few ping-pong balls, a spray bottle set on fine mist with alcohol, and of course something to tie-die, preferably bandanna or a T-shirt.
11 comments
Apr 19, 2012. 11:01 AManafelix says:
Would this work with non-Sharpie brand permanent markers (like knock-off brand markers)? I've only seen this done with Sharpies, but I want to do this for a summer camp project and name brand markers are simply too expensive for so many children.Thanks!!
Oct 24, 2011. 5:10 PMsafyrmwn says:
Water will not work. Sharpies (permanent markers) are water resistant, but the ink will dissolve in alcohol. The alcohol is the key. Rubbing alcohol or denatured alcohol will work as well. As long as you heat set before washing they will hold up to repeated washing. PS - Black markers work great on darker fabrics too.
Oct 22, 2011. 6:08 PMkmix1 says:
Could you use water instead of alcohol?
Jun 2, 2009. 5:37 PMbuildingstuffisfun says:
thats rad
Apr 26, 2009. 4:10 PMpeanut5o5 says:
this is soooo cool!
Jul 8, 2008. 4:14 PMSunny124613 says:
I would try this at home,but I only have black markers!
Feb 10, 2008. 2:52 PMGorillazMiko says:
Really easy way to do this, and not that messy either! Great job! +1 rating.
May 30, 2008. 7:29 AMBarbLyle says:
how much alcohol did you use in the waster bottles? The instructions didn't share......... thanks
Mar 14, 2008. 1:48 PMhutt says:
Maybe, if you use an ink made for fabric it will resist better to repeated washing imo, but the effect is pretty cool!
Feb 11, 2008. 8:16 AMBabyshoes says:
Cool! How does this hold up to repeated washing?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pkadams
