3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
TYE-DYE made with sharpies
Step 2Set up
Set up
Take the bandanna, tennis\ping-pong balls, and rubber bands. By the way to have one ring use one tennis ball, if you want two rings use two tennis balls and so on. If you are planning to use more than three balls, I would recommend ping-bong balls. Put the ball(s) in the middle if you are using one, or put the balls at least two inches apart. Then grab the fabric around the ball and tie the rubber band really close to the ball, if there is enough room put more rubber bands every two inches or so. If there are more balls do the same thing to them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pkadams
