TZ -1,000 Knex Ten Shot Pistol
3,341
5
36
Published
Introduction: TZ -1,000 Knex Ten Shot Pistol
Here it is the one the only TZ 1000!!! This amazing gun has a ten shot magazine that has never jammed over the hundreds of times I have shot it. Also it will shoot 35-40 feet and can pierce a box at 3 feet with one rubber band.
PROS:
Sturdy
light weight
10 shot mag that never jams
can shoot 35-40 feet with one rubber band
good looking
true triger
cons:
uses a decapetated orange connector.
Tell me what you think
Step 1: Magazine
Okay here we go. To start off we are going to build the magazine.
Step 1: build both
Spep 2: build both
Step 3: add white rods
Step 4: add parts you made in step 1
Step 5: add second panel and you are done with the mag
on to the next step >>>>>>
Step 2: Handle
Now the the handle.
Step 1: build both
Step 2: build
Step 3: build
Step 4: add yellow and blue rods
Step 5: add both parts
Step 3: Trigger
Okay now this is easy. Just build it
Step 4: Barral
Now I tried to make this as easy I can.
Just follow the pictures.
In the 4th pic cut where the yellow box is.
Step 5: Mag Pusher
just build
Step 6: Firing Pin
okay last thing to build the firing pin. You need to use the black rod for the firing pin because it is stronger. I mean you don't have to but it will make the gun stronger.
Step 7: Putting It Together
Okay almost done.
Add mag
Add handle
Add trigger
Add ram
Step 8: Loading and Firing
Okay we are done. Now just load the bullets and put the pusher in. It is now done. Just pull back the pin and fire!!!
If you have any questions please use my orange board.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    36 Comments
    Noob. Don't comment so many times in a row.
    I'm confused about adding the trigger. Can anyone explain to me how to do it?
    What is that white thing in between the orange thing and grey thing?
    u could use a black ball joint socket. or a cut up grey connector. I use ball joint socket.
    good a step that doesnt hurt ur thumbs. Phew. :)
    im getting there... i think but my thumbs are kinda sore cus ive made 'nother gun already today. ouch. :)
    coolio
    superburb instructions i hav made most of ur stuff and this is 1 of the best thanx
    how does the trigger work to keep it from firing once you've loaded (cocked?) another bullet to fire?
    the triiger blocks the ram, itd different in real life and knex
    the small black or green pieces
    the orange piece
