Table Organizer Inspired by Scandinavian Design
10,114
186
21
Posted
Introduction: Table Organizer Inspired by Scandinavian Design
I can never seem to find my pens, erasers an other stuff when I need them. I decided to solve the problem by designing this scandinavian design inspired plywood table organizer. I love the striped look of thick blocks of plywood and I think It's very underused material.
The design is very minimalistic, the organizer fits well 3 pens (pencil, ballpoint and marker), phone vertically or horzontally, erasers and other small stuff and hard covered notebooks and even my sunglasses if needed.
PS. remember to check out the build video!
Step 1: Tools and Materials
This project is fairly simple. All the materials needed is a sheet of plywood, wood glue and some kind of finish if you decide to use one. I used 1.2cm sheet of plywood.
The tools I used for the build were a saw, orbital sander, powerdrill with a 1cm drill bit for wood and a sanding drum, a file, a sanding drum for dremel and some clamps.
Step 2: Preparing Strips of Plywood.
I had a ready right sized sheet of plywood for my project, it was about 30 cmx30 cmx1.2 cm. My sheet had this black epoxy coating on both sides of the sheet which I had to sand away. Simpler solution would obviously have been to use plywood that is not coated with anything. By useing 40 grit paper on my orbital sander it didn't take too long for me to get rid of the coating.
I wanted to end up with a 6 cm wide block of plywood so I cut the plywood into five 6 cm wide strips. Then I placed all the strips on top of each other to see how much I need to offset each sheet in order for me to get the angle I want to the ends of the block.
Step 3: Gluing the First Sheets
I guess I could have just glued all the sheets together and then used a router to make the holes I need, but I didn't. I decided to first glue together the two sheets that will be placed on top of the block. Before gluing the strips I had to make 2 wide holes to the top strip. Those I would use for my phone and a pocket sized notebook. I measured the holes so that my phone would sit there both vertically and horizontally in slight angle just in case I wanted to use it to watch some videos. The same holes fit also for my small notebook (and surprisingly for my sunglasses also).
I used a drill to get rid of most of the material and then I filed off the rest. Then I rounded the edges slightly with a dremel and a sanding drum.
Then I was ready to glue the two top sheets of plywood on top of each other. I made sure I didnt get any glue in the bottom of the holes because it wouldn't be easy to sand it off from there. The little glue I still maaged to get there I just swiped off with peace of paper as soon as I had clamped the thing down.
Step 4: The Second Gluing
After the first twwo sheets were glued I needed to add one more sheet of plywood to the block because I wanted to make a deeper hole than the two first ones for eraser and other small stuff.
I drew my design on the wood and did excatly the same thing that I did with the first holes except this time I used a power drill with bigger sanding drum to speed thing up with the filing. After I had my hole with rounded edges I glued the third and the fourth layer of plywood to the bottom of the block.
Step 5: Cutting the Slot and the Final Gluing
After the glue had dried I sawed the ends of my block to the rough angle I wanted. Then I sawed two slices off one end of the block. I kept the other slice and I threw the other one away. I could have just sawed one slice off the block and used a longer sheet of plywood for the base. At this point I sanded the sides of my pieces that would be pointing inside the slot on the block becasue that area would be hard to sand after the gluing. I then glued my pieces on top of the bottom layer of plywood. I noticed that it was VERY tricky to glue down such narrow skewed piece of wood.
Lastly I drilled some holes for my pens to the other end of the block and sanded down all the edges to their final shape. Then I put some oil on the thing to make it slightly darker and voal√°.
Thank you for reading my tutorial and sorry for my broken english.
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
16 Comments
While we are still using the British Imperial system here in the States, I was converting to inches to build a few of these and I know 12.7 mm is about a half inch. 1.2mm would be like those balsa wood airplanes I made as a kid..lol.
Thanks! I don't know what I was thinking... It should say either 12mm or 1.2cm. I'll fix it.
Organizer shape looks like the outline of the attached photo of this building in Hamburg, Germany. It's the Elbe Dockland Office building. Where's the plumb bob? Along with the Elphi (Opera House), part of Europe's largest urban redevelopment, the Hafencity.
Haha. It looks like the whing would tip over to the water if all the people went to the left side of the top floor.
NICE!! Nice to see things that are hand made and have character along with that personal touch. This makes a good Christmas gift.
Thanks! Yes, I agree, making everything on computer with a CNC machine or something would take a lot of fun out of the process just to achieve perfection.
Something similar, but went the other direction ...
Very nice! I am thinking of doing a monitior stand at some point. Maybe I'll do something like that. I have to say, I would have made that stand slightly wider so that the keyboard fits nicely underneath it. But otherwise it looks very cool.
This is so clean looking - really nice work. I'm so glad I saw this as well as I'm planning to do the EXACT same stacked plywood design for a separate project and it is cool to see how well it works. Cheers
Thanks. Nice to see other people also appreciating the looks of plywood.
