Also Watch the video
Welcome to my entry for the metal contest Is a quick project using a old tablesaw blade and plasma cutting the numbers, if you like remember to vote
It takes about an hour to make it and the only tool you need its the plasma cutter
Tambien Mira el video
Bienvenidos a mi proyecto , es muy sencillo y facil de hacer reusando una vieja sierra que perdio algunos dientes ,
Este proyecto esta en el metal contes si te gusta vota por mi
La unica herramienta que use fue un corte plasma y el proyecto de principio a fin tomeo menos de una hora en realizarlo
Step 1: Cleaning
Clean all the prints with acetone and a scotchbrite to remove the rust
Step 2: Marking
Everybody knows the position of the numbers XD use a angle square to mark them every 30 degree
Step 3: Ready for Plasma
The fun part using the plasma cutter set it with between 20 and 25 amps I made it freehanded it looks some rustic,
And YES I know the number 8 turns out ugly but I dont want the holes from side to side so a thin strip its left to hold the centers
Step 4: Mechanism Assemble
I bought a cheap clock mechnism for about 1.5 dollars I put some hot melt glue to the mechanism not necesarry but keep it center, Add a washer to cover the hole and assemble the rest of the clock
Step 5: Ready to Mount
It turns out very cool i mout it with a 1/8 inch screw in one of my workshop cabinet doors very easy to make
Thanks for reading until the end Hope you like it
