Introduction: Table Top Cocktail Multicade Pacman
Picture of Table Top Cocktail Multicade Pacman
In this instructable I will show you how I went about making my own Table Top Cocktail Multicade.
Step 1: Items Used
3/4 inch plywood. I wanted to use something strong and would take some beating as its meant to be portable.
http://www.homedepot.com/p/Sande-Plywood-Common-3-...
My screen is a 15 inch HDMI LCD screen with speakers
1/8 in plexiglass
Raspberry Pi
LED back light arcade controls
https://www.amazon.com/Easyget-Encoder-Joystick-Il...
Power strip. I used Amazon basic.
Power pass through with switch.
Step 2: Basic Planning and Cutting
Picture of Basic Planning and Cutting
This is where Ill give you my basic layout and how I went about laying everything out.
This will be different for you as all monitors as sized different and different cases.
I measured the over all width of the monitor as it will sit sideways in the case.
I took this measurement and added an inch leaving 1/2 on both sides once centered.
I then measured the over all height of the monitor as this with then be the width of the case.
I took this measurement and added 1 1/2 inch. this left me with room to put 3/4 inch ply on both sides to add my supports you'll see in the next few steps.
My control panel was suppose to be 6 inches but they came out to be 5 7/8 after my angle was added but I made it work.
The top angle down ended up being 37 degrees.
to wrap this up the last step was to save 3/4 inch on both side pieces for the end caps.
Pocket holed the inside together to give me a strong base to work off of.
Step 3: Supports and Screen Testing
Picture of Supports and Screen Testing
So a ton is happening here all at once and will do my best to explain. (and happy to answer questions below as needed)
The side supports as I mentioned before shown running longways with the monitor
- cut 1/2 inch longer than the monitor leaving 1/4 inch on each side for movement and adjustments.
I turned the monitor over on its face and measured to its tallest point this is were i got the height of the runners
offset the runners 1/8 inch lower from the top lip leaving room for the plexi glass.
install the side to side braces at the bottom of your runners and your set. (clearer pictures in steps below of the braces)
Step 4: Power Pass Through
Picture of Power Pass Through
Test fitting the power block.
Step 5: Adding End Caps and Control Panel
Picture of Adding End Caps and Control Panel
This is were I made mistakes. A ton of mistakes.
I had to walk away kick the bucket yell at my table saw.
This step it totally trial and error.
I added shims to the inside lip to screw the control panel to for easy access. drilled and recessed the screws as shown.
Step 6: Fitting the Plexiglas
Picture of Fitting the Plexiglas
Straight forward here cut the Plexiglas to fit.
I then measured the monitor case to the screen took then and put it on the plexiglas taped the back side and painted it on the back side.
this turned out better than expected.
Step 7: Drilling the Control Panel
Picture of Drilling the Control Panel
This step is totally user preference.
my button lay out started with 1.5 inch spacing between all buttons.
first row is .5 inch lower
I used the picture layout as above minus the left and right triggers
Joy stick cut out then above that is my start and select buttons
Step 8: Prepping and Painting
Picture of Prepping and Painting
This is where it started to take shape and looking more like a finished product.
Step 9: Adding Electronics
Picture of Adding Electronics
I will not go into detail on the games or raspberry pi. Some quick searching will give you tons of info.
Wired the pass through to the power strip and just started putting it all together.
Step 10: Last Call
Picture of Last Call
A couple of issues I ran into.
When I would flip my master switch giving power to all my electronics my pi would time out looking for a video source.
This caused me a ton of issues until I learned I could delay the start up on the pi. My good buddy David was nice enough to do this for me.
Being a cocktail style cabinet you will have to program the games to rotate from player one and two between turns. (very time consuming)
Please overlook my grammar mistakes.
Happy to answer any questions with wood work or project related.
handmadewithashley (author)2017-08-10
This is super cool! I love the shape of it :)
Thank you!
jrobinson1987 (author)2017-08-10
So I've been wanting to build one of these in the same style. How did you program it to flip the screen on each turn. Was this hard to. The main reason I haven't started making one yet.
jones424 (author)jrobinson19872017-08-11
My good friend David helped me with this step.
In the settings you have to orientate the screen where to look for player one.
after that in the settings menu of each game you have to change the screen style to cocktail vs upright.
only about 100 games will work in this set up. im sure more but at the moment that is also enough to pass the time.
About This Instructable
1,081views
50favorites
License:
Bio: woodworker
More by jones424:How to Find an Instructable MemberLive Edge Standing BarLighted Wooden Pumpkin
Add instructable to:
