3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Table for Electronic Dreams
Table for Electronic Dreams is a table which reveals the hidden electrical activity of nearby electronic objects. Through this interaction, people will develop a greater awareness of the invisible workings of their electronic devices and the limits of human perception.
Step 1Gather parts!
Gather parts!
You will need:
PARTS LIST
15 circuit boards
15 LM324 quad op amp
15 14-pin sockets
60 white LEDs
60 induction coils*
* Currently I am using coils from Digikey part number M10013-ND. The inductance is 4.7mH. They do not look like the ones pictured in this instructable.
60 10 ohm resistors
60 10M ohm resistors
60 1K ohm resistors
30 100K ohm resistors
15 10 μF capacitors
60 0.1 μF capacitors
You could change these numbers if you want to make a smaller table. There will be 1 quad op amp, 4 LEDs and 4 induction coils for each board.
For the table:
1/4 inch translucent white acrylic 33" x 21"
1/4 inch clear acrylic 33" x 21"
aluminum u-channel
For op amps I am using a quad op amp LM324, but you can use any op amp chip.
124 comments
1-40 of 124next »
Mar 9, 2012. 10:27 AMmaixy says:
which symbol represents the coil?
(i am a fish...~_~)
Oct 26, 2009. 4:31 PMmarcinek__85 says:
My unit works but no longer works when I use a wi-fi or bluetooth. What do you use the coil? 470UH or 1000UH?
Sorry for my English.
Dec 26, 2011. 5:35 PMpranav vempati says:
How did you rectify your problem.... ( LEDs always on) ???
Jun 18, 2009. 1:34 PMsnoopdogg416 says:
hi i plan on buying the induction coils from http://www.digikey.ca/ could anyone paste the part # or link as to which one i should order for this project.
thanks
Jun 24, 2009. 2:01 AMDMcC says:
Hi snoopdog416 My son and I have been experimenting with the circuit and we were struggling with the best coils to use. I can advise now that in our experience it dosent appear to be a big issue what coils you use. We have managed to get the circuit to work using a wide range of coils and even got it working with a small section of straight wire in place of the coil !! Please note our test circuit was set up on a bread board using a number of small connecting wires. The small connecting wires may have had an impact on the sensativity of the coil. If I was you I would test your circuit with a cheap coil or section of wire before I purchased 60 new coils. Cheers D McC
Dec 2, 2009. 10:25 PMthexplanet says:
Hello DMcC,
Thanks for pointing out regarding the 3-cm wire in lieu of 4.7mH inductance coil,
however, can you please share the snap /picture of your bread board setup for this,
as I want to make this, and i am not that good into electronics, and i see this is dual sided PCB.
so, i would like to test it on bread-board first.
Thanks in advance.
Dec 3, 2009. 8:34 PMDMcC says:
Hi thexplanet
Unfortunately I have moved home since I played around with this circuit (back in June 2009) and dont have ready access to the breadboard.
I would  recommend that you set up the circuit a replace the coil with a short section of wire and see if that works for you. My son and I discovered that a short section of wire worked quite well as a replacement for the coil.
good luch
D McC
Dec 9, 2009. 2:36 PMthexplanet says:
Thanks DMcC,
I did the entire re-design of this ckt, and got it working for an Inductor with 4.7uH
can you explain which mode is the LM324N is working in? or why is it only LM324N? being used.
Is it RF / Microwave or EM?
Thanks
Dec 26, 2011. 5:33 PMpranav vempati says:
Can you please post the redesign of the circuit ???
Jun 25, 2009. 10:01 AMsnoopdogg416 says:
Hi DMcC Thanks for you input, I really have no experience using induction coils. I would appreciate it if you could perhaps paste a couple links from digikey.ca as to what coils would be appropriate for this project and then i could order a select few and experiment with them before i purchase a large amount. There are so many types on digikey that its overwhelming! thanks
Jun 25, 2009. 10:03 PMDMcC says:
Hi snoopdog I have had success with the following coils from a local company
http://www.altronics.com.au/index.asp?area=item&id=L8260
http://www.altronics.com.au/index.asp?area=item&id=L6230
But as mentioned in my last post I don't believe it really matters what coil you use as we also had success with using 3 cm of wire in place of the coil.
If you set up a test circuit on a bread board you will see for yourself that the coil rating is not important.
All the best
D McC
Dec 26, 2011. 1:15 AMpranav vempati says:
The LED's are always on..... When I bring a cell phone in, LEDs are flickering.... Can anyone suggest what should I do???
Nov 25, 2011. 2:40 AMnimit1994 says:
the minimun order for the induction coils from Digikey is 1000 which is too high and too expensive. Does anyone know where i can get the induction coils needed?
Nov 13, 2011. 8:00 PMilpug says:
Amazing. So, have you found out whether or not cell phones dream of electric sheep?
May 5, 2010. 8:28 AMmr panerai says:
hi....i'm new here...how can i get the schematic of this cool stuff (or maybe anyone selling the pcb completely with all componens (how much it cost?)
all email are welcome sekutu@hotmail.com / tomz_eternity@yahaoo.com
Mar 31, 2011. 11:21 AMMechtek says:
(removed by author or community request)
Mar 31, 2011. 4:38 AMGoJoeDimaagio says:
To make the board more sensitive do you just make a larger coil of wire?
Nov 13, 2010. 7:51 AMram.pai says:
hey can any one send me EAGLE files plzz???
Sep 5, 2010. 1:40 PMbraypaul says:
Hi great project i'm thinking of making a coffee table like this .
Sep 4, 2010. 7:45 AMCCOTTER247 says:
I was curious if you could post the eagle files please!!!!
May 23, 2010. 1:01 PMrailrun says:
Hi, I 've tried to build one board, but it didn't work. It seems, that the coil isn't correct. It's similar as you name here with 4,7 mH. Isn't it to high?!
Could you upload the eagle file for the board?
Apr 6, 2010. 3:18 AMchionatan says:
Hi, I would like to know, too, how to make the coil. I bought some copper.Could you give me some hints?
Mar 15, 2010. 10:56 AMaafaquehs says:
hey at least tell what size are the induction coils or instruct how to make em..
May 29, 2009. 6:39 AMRetroTechno says:
Pretty nifty idea. This basic idea could be the start of all kinds of cool projects. One little thing -- in looking at your schematic, I noticed you used capacitor symbols for the coils. Shouldn't they be inductors instead? Anyhow, they were clearly labeled, so no big whoop.
Oct 26, 2009. 2:27 PMmarcinek__85 says:
LED always on :/ what wrong? i'm change lm324 but don't work.
Sorry on my english
Mar 7, 2010. 9:27 AMmorriganfaye says:
you might want to check your resistors some might be bad or your ic  may also be bad. also makesure you power supply isnt to high if your current is to high it may effect all of those
Mar 7, 2010. 9:16 AMmorriganfaye says:
the schematic the IC ground and Vcc (power supply) are not attached thats pin 4 ground and pin 11 needs to go to the powersupply
Nov 9, 2009. 5:09 PMblaze-n-ferno says:
i had the same problem. prototyped it with a battery and it worked fine. but when i hooked it up to a 12v wall wart transformer with the 7805 they would all just stay on. what worked for me was to add the buffering capacitors to the input and output on the 7805. played around with the values of the capacitors for a while. but it fixed my problem. good luck.
Nov 24, 2009. 3:41 PMmorriganfaye says:
you will need to conect pin 4 to ground and pin 11 to voltage thats why
Mar 7, 2010. 9:24 AMmorriganfaye says:
If the circuit is not working, So everyone knows Pin 4 and Pin 11 on the schematic are not hooked up Pin 4 needs to go to ground and pin 11 needs to go to Vcc  or your powersupply.
Also if your local junk yard is nice you can ask to get some of the relays from the cars the relays have inductor coils in them that work with the table. I got about 50 relays for like 5 dollars.
Jan 28, 2010. 6:07 PMrhythmstick says:
Hi, what size are the inductor coils?
Nov 18, 2009. 10:55 PMawaite says:
Can i Buy one of these off u?
Nov 13, 2009. 3:44 PMkillroy says:
This is epic!
Nov 11, 2009. 8:22 AMSasha_HN says:
This is AWESOME!!!
Can  I use one of these,  "HIGH CURRENT, 330uh, 1.4A, 9x26mm"
or
"HIGH CURRENT, 1000UH, 0,8A" for coils.
Thanks
Nov 5, 2009. 11:39 PMmorriganfaye says:
what size are the size of the inductor coils
Sep 10, 2009. 6:17 PMmortaldoom780 says:
This is...so so cool. And the originality in that it was done with the simplest of devices - the LM741 - makes it that much better!
Aug 7, 2009. 9:21 AMbengerszewski says:
once one detects electricity, wouldn't that start a chain reaction with all the ones around it lighting up from that one led? I could be wrong, but just wondering.
Aug 28, 2009. 5:01 PMlaithp says:
I could be mistaken but I believe that what you are detecting is the slight electromagnetic field from the passing devices. the boards being built here are actually going to produce very little in the way of external fields and it will be close to the board center, far from the detector of the neighbor boards. So there shouldn't be much cascade if any.
1-40 of 124next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:andydoro(http://andydoro.com/)
This space intentionally left blank.
