3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Table for Electronic Dreams
Step 9Finishing touch
Finishing touch
Now you can place a sheet of translucent white acrylic above the layer of circuits to diffuse the light from the LEDs.
I used small white vinyl bumpers for the acrylic to sits on top of.
6 comments
Mar 31, 2011. 4:38 AMGoJoeDimaagio says:
To make the board more sensitive do you just make a larger coil of wire?
Jun 7, 2009. 9:00 PMakumasenshi says:
Can the LEDs be replaced with colour changing LEDs? I haven't studied electronics for a few years. The idea would be for the table to "shift" colour/s
Jul 19, 2009. 5:47 AMrevhead says:
you would need to buy RGB LEDs that change through their colours depending on the voltage/current that is applied to them. eg, low current = Red, mid current = Green, high current = blue, and every shade in-between and vice versa.
Jul 28, 2009. 2:31 PMgreenbean says:
It would be easy! You would just replace the leds with the RBG ones. The table is meant to change in brightness when the circuits induct more or less. Instead of getting brighter and dimmer, it would get bluer and redder!
Jul 30, 2009. 11:52 PMrevhead says:
are you talking about the RGB LEDs that have two legs or four legs? if you are talking about RBG LEDs with two legs do you know where i can get some because i have a project in mind and i cant seem to find any, not sure if two leged RGB LEDs even exist? if anyone can help me out on this it would be great, CHEERS!!
Jul 12, 2009. 3:23 AMJChevin says:
I'm not sure, but it would be cool (and very difficult) if the lights changed color depending on how much of the "electricity" was given off by the device near it.
May 26, 2010. 3:16 AMakumasenshi says:
 Did anything ever come about with the RGB LED's? Looking at actually making a wall out of this design.
Jul 23, 2009. 6:30 PMshehadehd says:
How would one go about making an indeuction coil using magnet wire. I tried wrapping some magent wire around a metal center but it didn't pickup anything. Is there a optimal specification for the coil. If so, what works best. A link to a product would be greatly appreciated.
Jul 23, 2009. 8:49 AMsynthetase says:
i would layer safety glass on top of the acrylic if you plan on using it as a primary work surface. it's more stable and scratch resistant. if you could find frosted safety glass that'd be beautiful.
Jun 8, 2009. 12:36 PMSJBarag says:
How thick was the translucent acrylic that you put on the top side? It appears to be fairly thick, but I can't tell. I'm interested in building one with additional modifications and will be using it as my primary workspace, so I don't want to flex under the weight of books or a laptop.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:andydoro(http://andydoro.com/)
This space intentionally left blank.
