Table Light
Introduction: Table Light
So here is an instructable for a great nighttable light. It's easy to make, I use it often and I think you will like it.
Step 1: Size
You need 4 woodboards which are 20 cm, 7 cm, 0,5cm long.
You also need one woodboard which is 12 cm, 12cm, 1,5cm for the bottom.
4 sticks 4 cm, 0,5cm, 0,5cm
8 very tiny woodblocks
and a light!!!.
Step 2: Sketching
This is the pattern for the sides, first you have to make a sketch.
Step 3: Copying
Now you have to copy the sketch and you have to glue it on the woodboards so you can saw better.
Step 4: Sawing
You have to saw the woodboards very carefully.!!!!!
Step 5: Stecking Together
If all sides fit together, you can wrap off the paper.
Step 6: Glueing
Now you can glue the pieces together, but be careful:-)
Step 7: Grinding
Now all the paper must be grinded off.
Step 8: Glueing 2.0
Now glue one stick in each corner, to hold the board with the light bulb.
Step 9: Electronics
Now make a hole in a woodboard and fix the electric part with the light bulb on it. The light bulb has to match perfect in the piece of wood.
Step 10: Glueing 3.0
Now you have to glue 2 tiny woodblocks in each corner.
Step 11: The Cable
Make a rekruiment were the cable matches into and glue it to the bottom.
Step 12: Holes
You need different sizes of drills. Make as many holes as you want.
Step 13: Beautying
Now make everything beauty, than you are finished.
Step 14: Finish
You made it! You are finished.If you have any questions please write a comment:-)
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
