Introduction: Tablet Power Socket Fix & Increase Sound Output. ++easy to Open!
Picture of Tablet Power Socket Fix & Increase Sound Output. ++easy to Open!
 Have to lean on the plug to get it to charge? want to increase its sound output? its only 4 months old and weak design errors are making it unreliable , i did not pay for the extended warranty.as it was not an expensive tablet.
"do you want to buy the extended insurance..blah blah blah.. for £20?"________________no i wont drop it.
" if it breaks we will replace blah blah blah"________________________  what about my information, I will fix it.
"antivirus.. blah blah blah.. for £20?"________________android antivirus are you serious,i have a real computer
Step 1: Supplies
Picture of Supplies
new plug and socket, i chose one bigger and much more reliable than the original,
small screwdrivers,
wire cutter/ stripper
iron and solder
sharp and knife file
multimeter and sticky tape
heatshrink and lighter
Step 2: Open the Case
Picture of Open the Case
i found no external screws, luckily i did not have to remove the front screen or anything drastic.
  • remove your sd card.
i found i could push a thumbnail in a groove around the edge, so i guessed it was a snap fit cover ,
  • starting at a corner away from buttons i slid a flat screwdriver around the edge at about 45 degrees , only allowing a few mm of the blade in at a time, hearing the clips pop as i went round.
  • when opening there will be a wire going to the speaker.
  • and the volume and power button will fall out.
Step 3: Your In!
Picture of Your In!
disconnect wire ribbons by lifting the tabs on the wire ribbon connectors then pull them.
, there was sticky tape holding stuff in place.
and remove the two screws.
so you can get to the where the power socket is soldered on.
Step 4: Flip the Board
Picture of Flip the Board
be very carefull with the wire on the left of the board. the connections look weak.
Step 5: Solder on a Couple of Wired
Picture of Solder on a Couple of Wired
there is more sticky film on the back of the board , lift it out the way.
locate the power jack
solder wires on there, put some solder on the contact , then put your wire on the solder and heat and as soon as it sticks remove, im sure its easy to damage stuff in here.
Step 6: Route the Wire
Picture of Route the Wire
the was a clear area on the left so make the wire exit.
make sure the circuit board returns flat into its placement.
i put the wire next to the battery, (silver packet)  , as to avoid the speaker,
tape the wire down.
Step 7: Attach a Power Socket,
Picture of Attach a Power Socket,
+ is at the end opposite where the plug goes in, the otheres are -
i wrapped it in electrical tape and heat shrink.
was originally going to use 9v battery snap for connector ,but these are easy to apply backward voltage into(butter fingers)
Step 8: Wire Exit Hole
Picture of Wire Exit Hole
i used a soldering iron to make the initial dent then tidied with scalpel and mini file.
the new location is much more convienent when using after market case.
Step 9: Remove the Original Plug
Picture of Remove the Original Plug
cut it off then  strip a bit off, check the polarity, white stripe is negative for me.
you can test with multimeter of briefly connecting to tablet to see if it works (not advised really)
i found the wire to be too short for me so i extended it from 1.2m to 3m
Step 10: Twisty Wire Test Then Connect
Picture of Twisty Wire Test Then Connect
i tested with temporary connections to see if i had made any mstakes , all ok so go ahead and solder the wires together and wrap in heatshrink.
Step 11: Make It Sound Better?
Picture of Make It Sound Better?
as i had the case open,
AT THIS POINT YOU COULD JUST REATTACH THE RIBBONS  AND SCREWS THEN SNAP THE THING SHUT AND YOUR FINISHED.
  • i decided to make the hole which the sound comes out bigger,
  • also on my case i removed the muffling fluffy stuff opposite the speaker, i made a route for the sound so it comes out by the side of the tablet
cut with scalpel and peel off  the fluffy layer.. i did not like the white paper undernieth so i put some elecrical tape over it ,
Step 12: Enjoy Your Tablet!
Picture of Enjoy Your Tablet!
About This Instructable
5,153views
12favorites
License:
Bio: the a b c approach is not for me .all feedback welcome. thanks for looking. if you would like some assistance or are interested in ... More »
More by crazyg:Valentines Day Special,Ozone Fart Remover, Rechargeable Gas Hob Igniter,UV Generator, Chocolate Saddle LAZER GUIDED GOLF BAT CLUB RACKET PUTTER
Add instructable to:
