Tabletop Pull Back Tri-Mode Spring Motor Rolling Chassis
Introduction: Tabletop Pull Back Tri-Mode Spring Motor Rolling Chassis
Tabletop Pull Back Tri-Mode Spring Motor Rolling Chassis is a fully 3D printed rolling chassis having 3 modes of operation, wind, power and coast.
My earlier 3D printed windup vehicles used a key or knob to wind the spring. This vehicle uses a floating pinion gear designed to wind the spring when the the vehicle is rapidly rolled backwards. This is the wind mode.
Once the spring is wound, releasing the vehicle propels it forward until the spring is depleted of its stored energy. This is the power mode.
Finally, after the spring is depleted, a second floating pinion gear disengages the spring motor from the rear axle allowing the vehicle to coast. This is the coast mode.
This vehicle does not outperform my earlier designs for distance, but it does illustrate that there's always room for improvement!
I probably forgot a file or two or something, so if you have any questions, please feel free to ask.
Designed using Autodesk Fusion 360, sliced using Cura 2.3.1, and printed in PLA on an Ultimaker 3 Extended.
Step 1: Print, Prepare and Purchase All the Parts.
You will need to purchase 12 "AS 568" size 221 (1 11/16 O.D., 1 7/16 I.D., 1/8" section) o-rings for the tires.
I printed my parts on an Ultimaker 3 Extended using .1mm vertical resolution and 100% infill for "Axle Spring.stl", "Spring.stl", "Gear Spring.stl" and "Axle Rear.stl", the remaining parts at 20% infill.
Prior to assembly, test fit and trim, file, sand, etc. all parts as necessary for smooth movement of moving surfaces, and tight fit for non moving surfaces. Depending on the colors you chose and your printer settings, more or less trimming, filing and/or sanding may be required. Carefully file all edges that contacted the build plate to make absolutely sure that all build plate "ooze" is removed and that all edges are smooth. I used a flat jewelers file and plenty of patience to perform this step.
Study "Assembly.stl", carefully noting the locations and positions of the various components as assembly proceeds.
Step 2: Prepare the Axle Assemblies.
There are four axle assemblies to make; two gear idler small, one axle rear, and one axle spring.
Starting with the two gear idler small axles, press one "Axle Gear Idler Small.stl" into one "Gear Idler Small.stl". Once in position, there must be 4mm of "Axle Gear Idler Small.stl" extending from each side of "Gear Idler Small.stl".
Next, is axle rear. Press one "Gear Axle Rear.stl" onto one of the splines on "Axle Rear.stl". The gear must be centered on the spline. Press the remaining "Gear Axle Rear.stl" onto the remaining spline on "Axle Rear.stl" and center the gear on the spline.
The final axle is axle spring. Start by pressing "Spring.stl" onto the spline on "Gear Axle Spring.stl". The spring must be centered on the spline. Next slide the spring and axle assembly into "Gear Spring.stl" noting that the correct orientation is when the cylinder on the end of "Spring.stl" aligns with the cylinder slot on "Gear Spring.stl". Make sure the cylinder on the end of "Spring.stl" is fully inserted into the cylinder slot on "Gear Spring.stl". Finally, press "Cap Gear Spring.stl" into position on "Gear Spring.stl".
Step 3: Assemble the Right Side of the Chassis.
Place the rear axle assembly into position in "Chassis Right.stl".
Place one of the gear idler small assemblies into position in "Chassis Right.stl", then press "Chassis Center.stl" into position in "Chassis Right.stl".
Press "Axle Gear Idler Large.stl" into position in "Chassis Right.stl". Slide one "Gear Idler Large.stl" onto this axle noting the orientation. Slide "Spacer Axle Gear Idler Large.stl" onto this axle.
Press the axle spring assembly into position in "Chassis Right.stl", noting that the cap gear axle spring part is nearest "Chassis Right.stl".
Slide the remaining "Gear Idler Large.stl" onto "Axle Gear Idler Large.stl" noting the orientation.
Step 4: Finish the Chassis.
Press "Chassis Left.stl" onto the chassis right assembly. This can be tricky to align all the axles, so be patient.
Step 5: Prepare the Wheels.
Place one of the purchased o-rings into each o-ring slot on all wheels. The rear wheels require 4 o-rings each, the front 2 o-rings each.
Step 6: Install the Wheels and Test.
Press one of the rear wheel assemblies onto one end of "Axle Rear.stl". Press the remaining wheel onto the remaining end. Carefully note the alignment of the wheel spokes.
Press "Axle Front.stl" into one of the front wheel assemblies, slide the axle into position in the chassis assembly, the press the remaining front wheel assembly onto the remaining end of the front axle again noting the alignment of the wheel spokes.
The front and rear wheels should rotate freely in the forward direction. When the rear wheels are rapidly rotated in reverse, the wind floating pinion (the gear idler small assembly nearest chassis right) should rotate into position and engage with the winding gear (the gear idler large nearest chassis right) and wind the spring. Rolling the vehicle rapidly in reverse (no further than 30") should wind the spring. When released, the vehicle should accelerate forward and coast after the spring energy is depleted. If there is any binding, make sure "Chassis Right.stl" and "Chassis Left.stl" are not warped, and are parallel to each other.
Good luck and I hope you like it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
Greg, love your design work and sense of style. This one has been added to my long list of projects to try. I went looking for the o-rings on the chinese sites where I get a lot of my components and they don't sell AS 568 size 221 o-rings, everything is in metric. After a little research this is what I found, perhaps it could help others looking for the part.
From what I could tell the 221s have an inner diameter of 36mm so as long as you are somewhere around there you should be good, right? I ordered the 44mm(OD) x 36mm(ID) x 4mm(CS), I was able to get 20 of them for about $5. I suspect the 40 x 36 x 2 would also work
Also you may want to change your description of your o-rings, I think you have the ID and OD reversed.
Thank you for sharing
Hi Christyl,
Thank you very much and I am glad you enjoy my tinkering!
I purchased this kit of o-rings: I've bought quite a few of these kits in both metric and standard.
I've know people who have tried size 220 through 222 and they all fit well, though the 220 did fit tight. Yours should work great.
And many thanks for the correction on the diameters (that would make for an interesting o-ring). I depend on people to keep me in line, and thanks to you I believe I've got this one correct now.
Thanks again!
One more question, I printed the front and back wheels, in the picture they look about the same height but the front wheels printed significantly smaller. 50mm vs 40mm all the recommended o-rings are the same size. I'm a little confused please enlighten me.
Well that is indeed curious. As designed, they are all be the same diameter (40mm). The rear wheels are wider (e.g. 4 o-rings as opposed to 2) for traction. I'll check the files again when I get back to the computer.
I'm very sorry for the difficulties you've encountered with this model.
Great project.Thank you!
Thank you so very much, I'm glad you enjoyed it!
Nice design. I like that they can see how the gears work. I'd like to do the wheels differently. Have you made the fusion 360 files available somewhere?
Thank you so much and I'm glad you like it!
I'm very new to both Instructables and Autodesk Fusion 360, and have yet progressed to the point where I know how to post the files. I'll read up on that and try as soon as possible to post the wheel files.
Thanks again!
loos to be a couple parts missing. the axle for the idler, and the front axle? can you clarify??
ive got it 1/2 printed, might have to cad up the parts myself?
