3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tabletop Tesla Coil
Tabletop Tesla Coil
Step 1The frame
The frame
The frame of the tabletop Tesla is made entirely of half-inch (12.7 mm) PVC pipe. There's no point giving you exact dimensions of the stringers and risers because they depend on how big your secondary coil is. You can scale the frame up or down as you wish. I used a 12 inch long cardboard tube for mine, making the footprint of my coil 14 inches by 11.25 inches.
Study the pictures and you will see how the frame is made. The configuration as made requires the following joints:
(4) 90 degree elbows;
(8) "T" joints
(2) end caps
All the rest is straight half-inch tubing, cut to length. NO CEMENT WAS USED TO JOIN THE PARTS and none should be used. The friction fit of the tubing is reasonably strong, and leaving the joints unglued allows you to take the frame apart to work on the coil, make adjustments or repairs, etc.
The center uprights consist of three T joints each, stacked vertically. Short lengths of tubing connect these. If you make a bigger coil these length will have to be adjusted accordingly.
The cross piece that runs underneath and parallel to the secondary coil has to be drilled for the primary supports. Find the center point of the cross piece and drill two holes so that the primary form in centered on the secondary. Again, I can't tell you exactly where, because it depends on what you use for your coil forms. But center it and it will be fine. See the page on the Primary for more details of the mounting method.
The secondary is supported by plumbing caps and tubing adapters inserted into the cardboard tube. The tube I used is 1.75 inches in diameter (it's a thick-walled cardboard paper towel tube). I had to experiment at the home center to find off the shelf PVC plumbing pieces that would fit, but I found ones that slip in closely. Again, no glue was used. You want to be able to remove the secondary for maintenance or replacement.
In the two topmost T joints insert plugs to support the brass terminal posts. These can be anything non-conductive--cork, rubber, etc. I found wine corks fit nicely. Push them down equally on each side until they are level with the top edge of the secondary form. Above them fit a length of PVC tubing. Exact height is not too important; they should be tall enough to keep the terminals away from the active coils to avoid arcing. Mine are four inches tall each.
Drill 3/16ths holes in the center of two PVC pipe caps for the terminals. Drill small holes--about 1/8th inch--in the support tubes opposite the ends of the secondary coil to feed the secondary's wires through. See the step about the Terminals for final connections.
170 comments
1-40 of 170next »
Apr 23, 2012. 4:39 PMdisappearingshadow says:
http://www.ebay.ca/itm/LOW-GLOW-NEON-9500-VOLT-TRANSFORMER-FITS-LOWGLOW-AND-MANY-OTHER-NEON-BRANDS-/380430895286?pt=Motors_Car_Truck_Parts_Accessories&hash=item589372c8b6
I was thinking of getting this one. Do you think it would work with this project?
Apr 23, 2012. 7:55 PMdisappearingshadow says:
Okay thanks :D how about this one?
http://www.ebay.ca/itm/New-10kv-30mA-Neon-Power-Supply-Neon-Transformer-UL-Series-A410EL-/150798592048?pt=LH_DefaultDomain_0&hash=item231c4be830
Apr 24, 2012. 7:17 AMdisappearingshadow says:
I am having a lot of trouble trying to find one in Canada. I don't supposed you know any good sites.
Apr 24, 2012. 8:23 PMdisappearingshadow says:
I went to a neon sigh place and they gave me Ann allanson power pak it has 35 ma 7200v complies with secondary ground fault protection requirements please tell me it works
Apr 6, 2012. 2:17 AMThe MadScientist says:
What's the current output of your transformer?
Apr 16, 2012. 1:29 AMThe MadScientist says:
Cheers
Dec 24, 2011. 7:37 AMsomebody12345 says:
I have the exact same cardboard tube.
Mar 3, 2011. 7:42 PMteslacoilguitaramp,helpmeplz says:
sorry to burst you bubble, but i think that is a fancy spark gap not a Tesla coil. but with that design should get some nice arcs.
Mar 3, 2011. 7:53 PMteslacoilguitaramp,helpmeplz says:
i wanted to know how you connected the capacitors? wich is how i found this, i need some capacitors, and i want to play it safe and make 2 or three large ones that could hndle the output almost alone but for safety and emergency measures..
Feb 26, 2011. 8:32 AMjimmydean123 says:
i have everything wired up correctly, but my tesla still won't work. The spark gap won't spark, and we know it isn't the transformer because it had enough power to burn out my multimeter. Any suggestions?
Feb 26, 2011. 12:30 PMjimmydean123 says:
My capacitor is made up of 8 peroxide bottles with a monster can inside each. I have not tested it but i can hear it when i turn it on.
My spark gap is set up so each knob is extremely close to touching but is not touching.
My secondary is 24 gauge magnet wire gauge wire with approximately 443 windings.
My primary is 12 gauge wire with 5 windings. I think it might be in the opposite direction.
My transformer is a Pro Series Low Glow neon sign transformer. The input is 12-15VDC at 5 amps (max.). The output is 9500V; the output amperage is 30 mA. It also has an 8 amp fuse.
Feb 27, 2011. 9:54 AMjimmydean123 says:
thanks for the advice but i guess i'm gonna have to buy a new (or old i guess) transformer anyway becausewhile trying to override the GFI i shorted out the transformer any suggestions on a low cost transformer that would fit the bill
Feb 2, 2011. 9:44 PMbigrob121 says:
Where did you get the spherical top load in the "Table Top Tesla Coil Test" Video? Big props on your bipolar TC instructable.
Aug 17, 2009. 3:46 PMCrtek says:
can i use a CRT monitor instead of this?
Dec 27, 2010. 4:59 PMpunkzter says:
Do you have any insight for using/taking apart the CRT to get the flyback?
Also, does the spark gap need to be as complicated as yours? I have seen some that are just two screws. Thanks!
Dec 27, 2010. 6:15 PMpunkzter says:
So I wouldn't have to hook it up to a vacuum cleaner for it to work?
Aug 24, 2010. 2:29 AMoctavian234 says:
If you dont have enough leyden jars will your tesla coil not arc?
Aug 24, 2010. 9:47 PMoctavian234 says:
Ok. Thank you. I got my diagram from a different instructable but his directions were hard to follow. I'm going to use your capacitor idea and Coil idea.
Mar 5, 2010. 6:17 PMrodsy says:
 im sry i dont relly get science dat well so im askin , why do u need a capacitor?
Jun 13, 2010. 10:04 AMxio says:
and i would like to say this in the nicest way possible, but i think that you should'nt start things on this big of a scale if you don't fully understand what a Tesla coil is.
Jun 13, 2010. 10:01 AMxio says:
it generates power for the tesla coil. (giant battery)
Nov 12, 2010. 6:29 PMwii552 says:
no not at all. A capacitor stores energy, not makes it. All that the caps do is make the pulses of electricity for the coil.
Jan 25, 2011. 7:08 PMjimmydean123 says:
it's like a baterey but it dosnt generaste power it stores it until thgat charge is big enough for it to discharge it
Jun 13, 2010. 6:57 AMnutsandbolts_64 says:
DCKV?!?! I don't need that much!?! It's just surprising how much power you put in there. How do you charge the capacitors? Do you use the NST there to charge 'em or what?
1-40 of 170next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:Mr. Apol
