3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tabletop Tesla Coil
Step 7The power supply
The power supply
For power I use an Allanson 7,500 volt neon sign transformer. It is current limited. As Mitch Tilbury writes in The Ultimate Tesla Coil Design and Construction Guide:
"Small Tesla coils that typically use NSTs will not require circuit protection as the NST is current limited and will draw less line current than the 15-A [15 amps] rating that is typical for building electrical outlets." (page 275)
I installed two RF chokes on the lines running to the coil. These are snap-on types sold at Radio Shack. They are there to block or reduce RF interference.
The Allanson unit is handy in that it has a pull-chain switch with a long string attached. You can easily stand two or three feet away and turn the apparatus on and off from a safe position. I mounted the NST on a pine plaque, well-shellacked, and put four hard rubber feet on the plaque to raise it and give it a more finished appearance.
6 comments
Apr 23, 2012. 4:39 PMdisappearingshadow says:
http://www.ebay.ca/itm/LOW-GLOW-NEON-9500-VOLT-TRANSFORMER-FITS-LOWGLOW-AND-MANY-OTHER-NEON-BRANDS-/380430895286?pt=Motors_Car_Truck_Parts_Accessories&hash=item589372c8b6
I was thinking of getting this one. Do you think it would work with this project?
Apr 23, 2012. 7:55 PMdisappearingshadow says:
Okay thanks :D how about this one?
http://www.ebay.ca/itm/New-10kv-30mA-Neon-Power-Supply-Neon-Transformer-UL-Series-A410EL-/150798592048?pt=LH_DefaultDomain_0&hash=item231c4be830
Apr 24, 2012. 7:17 AMdisappearingshadow says:
I am having a lot of trouble trying to find one in Canada. I don't supposed you know any good sites.
Apr 24, 2012. 8:23 PMdisappearingshadow says:
I went to a neon sigh place and they gave me Ann allanson power pak it has 35 ma 7200v complies with secondary ground fault protection requirements please tell me it works
Aug 17, 2009. 3:46 PMCrtek says:
can i use a CRT monitor instead of this?
Dec 27, 2010. 4:59 PMpunkzter says:
Do you have any insight for using/taking apart the CRT to get the flyback?
Also, does the spark gap need to be as complicated as yours? I have seen some that are just two screws. Thanks!
Dec 27, 2010. 6:15 PMpunkzter says:
So I wouldn't have to hook it up to a vacuum cleaner for it to work?
Nov 12, 2009. 7:17 PMEvilthingamabober says:
I have an old 7.5kv negetive ion generator transformer that isn't current limited. How can I make a ballast for it?
Nov 14, 2009. 1:08 PMEvilthingamabober says:
It's a 7.5 ion generator, here's a pic. The needle array was cut off.
Jan 12, 2010. 5:53 PMchriskarr says:
While you're correct about the ion generator being insufficient for a Tesla coil, you aren't completely correct about one thing.
In a DC Tesla coil, you don't need to have a pulsed supply but, rather, a constant-current supply and an inductor. The inductor stores the DC energy in its core and windings in the form of magnetic flux and allows the current (after it's charged) to pass through and into the capacitor. Once the capacitor is charged to a sufficient voltage to fire the spark gap, it will do so, at which point the potential in the transformer drops to near-zero and the magnetic flux experiences reversals. Since the gap is still conducting at this point, your core's magnetic flux 'dumps' its charge into the spark gap, as well, increasing your voltage to near two times the supply voltage. This does, however, require a rotary spark gap to occur.
Jun 17, 2009. 1:26 PMitsachen says:
Where did you buy your PS? How much did it cost?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:Mr. Apol
