Tactical Shotbow
3,416
14
133
Posted
Introduction: Tactical Shotbow
I like oodammo, I wanted to make a new knex gun, and I have heard alot about S0lekill3r's shotbow.  So I made a shotbow.  This shotbow is much more compact than sS0lekill3r's, and functions just as well.  I decided to put my dot sight I made a few weeks ago on it, and also to have a comfy forgrip.  I have not discovered how to put on the rubberbands in a one pull=2 shots configuration, so this is always a shotgun.  Hope you like it!
Credit to S0lekill3r for the mag, and that's it!
If you build one, please show me, I'll add it to the ible.
Pictures of any mods wanted.
Pro's
-compact
-has tactical rail on top
-forgrip
-exellent trigger
-10-round mags
-accurate
-high ROF
-looks sick
-100% reliable.  It has never failed me in the 100's of times I have fired it.
Con's
-very slow mag reload
-uses lots of white connectors
-can't really put into a semi-auto mode.
Lets get building!  Don't forget to rate and comment!
Step 1: Main Body
Okay, this is where the magic happens.  Very simple, I start with the middle layer.
Step 2: Handle
This is the handle and beginning of the stock.  Very easy.
Step 3: Trigger
This is a quik and easy step.  Follow the image notes.
Step 4: Stock
This is the stock.  Make it.
Step 5: Final Touches and Assembly
Yay!  Were're almost done!  Just a few things more!
How to fire:  You pull back the puller thingy untill the ramrods lock, then push it all the way forward.  Pull the trigger.  Repeat 10 times.
I can get a really high rate of fire going, the puller thing makes your life alot easier.
Step 6: Fun Pictures and Your Tactical Shotbows.
If you build your own Tactical Shotbow, show me!  I'll add it in this step.
I took some pictures of the oodammo in mid-air.  It is really cool, but fuzzy.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    135 Comments
    I built this and i'ts sweet i like this much more then your other guns!
    Looks and sounds pretty great from what you posted. I'd like you to add "shotgun", "gun", "true trigger", "dot sight", "crossbow", "Xbow" and any other adjectives you can think of for more attention. I'm favoriting it to build later before I rate it
    Thanks. Did you use Selezoina's trigger? Because that one is stronger.
    i had no problems with it
    and i do not have it anymore, as i do not have so many pieces^^
    Yeah, I had no problems with mine either, until seleziona posted those pics, and then mine started failing about a day after. Oh well, cool that you built it.
    After a year and I still remember this thing, and I totally love(d) it :D
    Lol thanks, but this is no where near that great. You should check out my bolt action gun forum post I made, that is a lot better.
    Idno why I liked it so much, probably cuz it was easy to handle,
    high accuracy (Oodammo) and errrr just good!
    anyways ill check it out :)
