Math. Love it or hate it, everyone must do it at some point in their lives. Some of us revel in numbers and equations and have a passion for math. This Instructable is for you, oh math lovers of the world.
This Instructable describes mental cube-root extraction: a cool math trick you can do to amuse and amaze your friends, and score some mean cubicle-cred with your fellow geeks. I can accept no responsibility for the social implications of using this skill (but then, as a geek, you probably already treat social implications of your geekiness with abandon, so it's all good).
At any rate, let's move on!
Update: Featured?!? Thank you so much Instructables, that means alot to me :-)
Update2: I know it's alot to ask from you folks, but please, vote for this in the book contest if you think it's cool. I would really appreciate that.
Remove these ads by
Signing UpStep 1A Note on Limitations
So, here they are:
1) This trick only works for perfect cubes, it will not work for any arbitrary 6-digit number
2) The cubed number must be an integer (whole number) between 0 and 100 (or 0 and -100). No fractions, no decimals.
For ways to expand the technique, see the last step of the instructable.
1. we get the digit sum of a no. by "adding across" the no. For instance, the digit sum 0f 13022 is 8.
2. we always reduce the digit sum to a single figure if it is not already a single fig.
3 .In "adding across" a no. we may drop out 9's. Thus if we happen to notice two digits that add up to 9, such as 2 and 9, if we ignore both of them; so the digit sum of 99019 = 1 at a glance.(If we add up 9,s we get the same result)
4. because :nine don't count" in the process, as we saw in3 step, a digit sun of 9 is the same as a digit sum of zero. The digit sum of 441,e.g = 0.
You may use this for Multiplication, Cubes , Squares etc.
you may also check weather your squared no, is correct or not.
I will explain it:-
take an example for 207.
square(207)= 42849
now add digits of LHS and RHS separately. we get
Sq(2+7) = 18
Sq(0) = 18
0=2+7
0=9
0=0
thus your calculation is correct.
take another example.
Sq(897) = 804609
sq(6) = 18
36 = 180
0=0.
http://www.instructables.com/id/Square_2_Digit_Numbers_Mentally/
Hope you like it :-)
