3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Take That! Taser
Take That! Taser
Learn how to protect yourself and how to keep your enemies at a distance with this high-voltage shocker! For other high tech projects, questions, or troubles goto ocalon.com!
Then take it a step further as you hack this project to electrify a defense grid (think small area such as a room or so) or use it as a defense mechanism to repel unwanted individuals from your stuff! My favorite use is as a shield on my robots where, when someone tries to pick it up will be in for quite a shock!... literally
First just read through the project, make sure to gather all the needed parts and tools and then you'll be able to create your very own defense taser.
Step 1Materials/Supplies
Materials/Supplies
Okay so first we begin with a parts list for the project:
1. Default materials: soldering iron (covered here)
2. circuit board scraped from a throw-away temporary camera
3. 3x2x1" project enclosure
4. Red SPST (single pole single throw) Pushbutton Switch
5. SPST Submini Slide Switch
6. 6" of stranded 22-24 gauge stranded wire (preferable 24 because its thinner)
7. Some AA batteries, 2 screws w/bolts, and a drill.
All these things are available at your local radio shack. Happy Huntings!
32 comments
Jul 6, 2009. 4:31 AMmbilalawan says:
how can we modify this circuit to give a rather 50,000+ volts shock
Apr 21, 2011. 4:06 PMunum says:
For 1700 volts go here:
http://www.instructables.com/id/Real-1700-volt-Camera-Taser/
Oct 4, 2009. 4:34 AMKin_Hell says:
Yes it gives around 300 on 1.5v so 3v would give 600, but the more you rank it the more likley it is to blow quicker
Apr 21, 2011. 4:02 PMunum says:
use this instructable to make a smaller transforming circuit. it sacrifices the indicator LED but is less then 1cm^3 in volume and can use up to a nine volt:
Jan 9, 2010. 7:24 AM2k000 says:
 i dont see the battery in the picture, where is your power source coming from?
Aug 9, 2010. 10:58 PMmasterserch says:
am i supous a aa batery but good question
Jun 23, 2010. 4:32 PMRomanader says:
Hmm... I wonder how a flyback transformer and a high-voltage joule thief would treat this project... Yeah... I actually go out of my way to be evil. It's satisfying to say the least...
Feb 20, 2010. 1:05 PMJavi93 says:
can i make the box out of legos? plastic would povide good isolation
Dec 13, 2008. 7:00 PMPadlock says:
Wow, this is so original...
Feb 10, 2009. 5:26 AMPyroMonger says:
It's not original at all because this 'ible' is also in a book I have - 101 Spy Gadgets for the Evil Genius - and it looks almost exactly like this in the book except for the stunning prongs. It's cool to show things you've seen in books but just remember to give credit to them.
Feb 10, 2009. 5:27 PMPadlock says:
You obviously did not see my sarcasm. Search "Taser" or "Stungun" and count how many of them are made from disassembled disposable cameras. It will be in the hundreds, I assure you.
Dec 31, 2009. 1:43 PMcdousley says:
mine is so original its made from a Nerf firefly flash circuit
Apr 24, 2009. 11:41 AMbylerfamily says:
There are only 2 pages on both searches.No hundreds of instructables,sorry.
Apr 25, 2009. 5:39 PMPadlock says:
Geez. You must not know what a hyperbole is, do you?
Apr 26, 2009. 5:06 AMbylerfamily says:
I do,but I like taking people to seriously.:)
Feb 10, 2009. 5:28 PMPadlock says:
And most likely the book got the idea from the internet, not vice-versa. This has been around since the merchandising of portable cameras.
Feb 21, 2009. 6:32 PMguydie5 says:
that it true but i think this one looks cool... But dang it i sure am sick of camera tasers
Nov 15, 2009. 10:08 PMqwaz says:
 Would the stungun still have the desired effect if I reversed the prngs and only had the heads of the screws showing?
Sep 13, 2009. 11:09 PMexpidition says:
Where do you connect the push button wires exactly? Or could you post a picture with the caption things
May 30, 2009. 11:34 AMscozzahisee says:
Nice looking gadget there. Does it rapidly arc electricity as long as you hold the button down, or is it a single arc per button press?
Aug 10, 2009. 2:49 PMlasermaster3531 says:
neither. at 330 volts, the arcing ability is limited to about the width of a human hair, .01 mm.
Jan 23, 2009. 9:02 PMWyle_E says:
That's actually a stungun, not a taser. The taser uses gunpowder to launch a pair of miniature harpoons, with trailing wires connected to the pulse generator in the weapon's grip. It's a much nastier weapon than a stungun, because the target can't just jump back and break the circuit.
Feb 6, 2009. 9:38 AMrunmgh says:
Actually, tasers use compressed nitrogen to propel the barbs. They can also be used as a direct contact stun device.
Jun 12, 2009. 5:03 AMfabrivassa says:
yep, nitrogen
Aug 10, 2009. 2:48 PMlasermaster3531 says:
or CO2.
Jun 16, 2009. 12:32 PMjdsoccer17 says:
what kind of camera did you use? im trying a kodak. i dont really know what to do
Feb 21, 2009. 7:20 PMguydie5 says:
hey anyone know if it would work if i attatched three compasiters to each others wires and then use a nine volt battery to recharge it
Feb 23, 2009. 7:18 PMPadlock says:
1. It's capacitor 2. With or without a circuit board? If you didn't use a step-up circuit then no, it wouldn't work. The most you could get is 27 volts, the minimum 9. It all depends how you wire it, and how you charge it.
Jan 16, 2009. 6:00 PMkimiharu says:
ooooh dangerous....
Jan 3, 2009. 6:43 PMDIY Dave says:
great instuctable much nicer than other camera tazer instructables
Dec 13, 2008. 10:01 PMac1D says:
another one..
Dec 13, 2008. 5:37 AMmrbob1000 says:
I made one of these like this, only thing is that i used the cold cathode transformer from a scanner. Works great, and has a continuous spark.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:weezoh
