Are there any hobbyist usable electronics parts inside a CFL? How do they work, anyway? And when they burn out, why have they burnt out?
Let's take some apart and see!
(This Photo by PiccoloNamek from Wikipedia. Hopefully this is sufficient to meet the requirements of the license; I didn't have my lawyer review the Gnu Free Documentation License)
Remove these ads by
Signing UpStep 1Take it Apart 1: cut a pry-slot
Unfortunately, even if only press-fit, the two pieces are usually too securely attached to just pry them apart with your hands, if only because one of the halves has only the glass tube to get a grip on. Sometimes the joining seam is loose and/or large enough to fit in a flat-blade screwdriver, but it is easiest (assuming you don't want to re-use the bulb casing) to cut a shallow slot at the seam with a hacksaw. Just hold the housing securely (in a small vise as pictured, or not), and saw a slot just barely through the casing - about 4mm.
Caution
Try REALLY hard not to break the glass fluorescent tube. Aside from sharp edges, fluorescent lights contain phosphors of unknown and possibly dangerous composition, and a small amount of mercury that you'd rather not have released in your home or workshop.| « Previous Step | Download PDFView All Steps | Next Step » |
Higher-wattage bulbs have a (somewhat) greater chance that their transistors would have survived the lamp failing; I have some nice E13007 transistors, and some really nice MOSFETS of which I can't remember the part number right now.
Kudos to WestFW for a nice -ible on CFL parts.
On the divergent thread:
Tritium is fine IF it's encased safely. Watches with tritium hands have been designed to keep it inside. Regulatory agencies are not always driven by science but often are driven by public outcry and ignorance. Ask a n* physicist who works with those things and they'll tell you the gas lantern mantles and watch hands scare is pretty much just that, scare tactics. Moral- don't grind up any of those things and eat them.
What a great spelunking tool to bring on the tour, a watch face that won't stop glowing no matter how dark it is or how long it has been in the dark!
