loading
Step 4: What does all that DO - How does a fluorescent light work, anyway?
A fluorescent light is a gas discharge tube. It works a little like a strobe tube, and a little like an LED. Once it's running, it will happily allow very large electrical currents to flow through some ionized gas. To prevent it conducting so much power that it burns out or blows fuses, you have to limit the current with some sort of external circuit (this is the part that is similar to LEDs.) This is the main purpose of the fluorescent ballast. (The other function of the ballast is to get to that "once it's running" state. This can involve filaments, high(er) voltage pulses, and stuff like that.)
The picture shows a simplified fluorescent tube and ballast. You'll notice that the ballast is an inductor. This is because an inductor can act as a current limiter 'for AC current without actually using up any power the way a resistor (as used for LEDs) would. A neat trick. The current through the inductor (and thus the lamp, since it's a series circuit) is proportional to the AC frequency, and the inductance of the inductor. If you've ever seen the magnetic-only ballast from a standard fluorescent light, you'll have an idea how large an inductor is required at the 60Hz AC that comes out of the wall.
<p>The fuse is often shrink-wrapped in one of the wires going to the ballast from the plug.</p>
Mercury is very toxic, but its not so dangerous in small amounts like this if there is no strong airflow it stays near the ground.
u do realize that the amount of murcury in one of these is not nearly enough to kill you, it wont even make u feel sick
Not the point--heavy metal contamination is cumulative. It accumulates in the body. If you eat shark too many times a week it can be hazardous for the same reason--them being near the top of the food chain we get the end results of their build-up. There are a lot of hazardous inputs that won't make you feel sick immediately.
<p>Your body takes in some and eliminates some so it is not cumulative. If it were cumulative, you could have only so much shark over your entire lifetime versus how much shark you can safely eat in a week. For health concerns, it is about how much you take in and how fast you eliminate it that results in either relatively safe or relatively toxic levels in your body.</p>
Shomas - Your logic isn't correct: &quot;Your body takes in some and eliminates some so it is not cumulative&quot;. The statement contradicts itself. Additionally, it is well established that residual tissue contamination from mercury ingestion is cumulative.There are several different chemical forms of mercury: elemental mercury, inorganic mercury, and methylmercury. The form of mercury associated with dental amalgam is elemental mercury, which releases mercury vapor. The form of mercury found in fish is methylmercury, a type of organic mercury. Mercury vapor is mainly absorbed by the lungs. Methylmercury is mainly absorbed through the digestive tract. The body processes these forms of mercury differently and has different levels of tolerance for mercury vapor and methylmercury.<br>Mercury vapor, is also absorbed in the sinus cavities and it is here where the behavior of the mercury becomes very strange. It has an affinity for nerve tissue and through the sinuses, attaches itself to nerve endings and steadily travels the nerve to the brain where it then permanently resides and causes damage.
oh i didn't realize it was accumulitive
<p>The accumulative argument is nonfactual and espoused by persons who do not know better. My comment above to Peeet explains why. </p>
&nbsp;are you super sure? I just broke one and I'm freaking out<br /> <br />
read below
I think some concern borders on hysteria and lack of common sense. If i should accidentally drop a fever thermometer (there i really dated myself) i don't think i would call the men in the space suits. The XEROX company tried to make a dental imaging machine based on xerographic principals. They found out that the residual mercury in the dentist's carpets "poisoned" the drum. The project was eventually dropped. The same also is said to hold true if somebody breaks a fluorescent tube in a room where a XEROX machine is installed. For us hoomons It is the mercury compounds that are dangerous and that is what accumulates in fish organs, etc. Mercuric chloride is a deadly poison. Years ago our chemistry teachers in high school would pass liquid mercury around the classroom. Now they fire a teacher if he even has a vial of the stuff.
Concern about mercury in CFLs does border on hysteria. You could spend months shattering 100,000 CFLs in one spot on your carpet, and once you had finished shattering the 100,000th CFL, you would finally have some cause for worry about mercury poisoning as an adult. <br> <br>The bigger problem with CFLs, where the hysteria is justified, is pets, children, and the elderly. Mercury affects these groups much more than adults, and children and pets might lick the carpet. So if you have a household with no pets or children, then there's not much to worry about with breaking a CFL. <br> <br>For those who worry about breaking them anyway, here;s a simple comment: think about the number of times you have ever broken a standard incandescent light bulb. Now divide that number by 10. Since CFLs generally last ten times longer than incandescents, this is the number of times you will break a CFL. Chances are this new number will be less than zero.
Yes, I remember being allowed to roll it around on our hands - that's really going back some!! I'm almost 60 - phew!!
True. Also it's not that much mercury. There are higher level of mercury it some fish.
Dismantling a CFL bulb is like a trip from the electronic hardware. There's a lot of things you could salvage. Thanks for this! I really needed a ferrite toroid for a joulr thief and now I have one, thanks to this guide.
I used a small hand saw before prying the bulb with a screw driver. The rest was easy.
This is very usefull for my project
to get mine apart I just whack the seam with a small hammer
I use this circuit for my flyback transformer driver
Darn, my buddy gave me a blown out bulb he had, looked like a CFL, he thought it was one too. <br>When I opened it, all I got was a capacitor wired to a glass glow bulb starter. <br>Is the starter useful for anything other than lightbulbs?
what can you do with the spaghetti stuff? :0
<strong>You eat it. </strong><br /> <br /> <br /> <br /> <br /> Just kidding ;D
It's a flexible, heat-resistant insulator. It's convenient for big capacitors on small boards, to spread out the components.
So could you put a correctly sized capacitor in parallel with the flourescent tube and correct the terrible power factor in these? <br> <br>
no because fluorescent tubes have to have ac current, or the mercury gathers on one side.
When it comes to harvesting components from CFL bases, be sure to test those transistors. I cracked one open that burnt out in my bedroom and found that the E13003 power transistors were short circuited (reading 0 ohms on a multimeter) between the base and collector, base and emitter, or all three pins.<br><br>Higher-wattage bulbs have a (somewhat) greater chance that their transistors would have survived the lamp failing; I have some nice E13007 transistors, and some really nice MOSFETS of which I can't remember the part number right now.
yes, you want to be careful harvesting components from bulbs that have actually burnt out in one way or another. The usual failure modes seem to take out several components. But these days the (subsidized) prices of CFLs are low enough that you can think seriously about harvesting brand new CFLs. (I think I've seen 4-packs for less than $5)
I had my first CFL die (early in my opinion), so as I do with incandescents, I wiggled and tapped on it to make sure it was getting a good connection in the socket. It was screwed in tight but it will light up for a couple seconds when I tap on it. What do you think is going on inside this bulb and is it salvageable?
One of the failure modes I've seen is that a positive-temperature-coefficient (PTC) thermistor (think of it as an inrush limiter, I think) will apparently overheat (perhaps due to other problems?) and have one of it's leads unsolder itself from the component body...
The PTC is what Chrysler used to use in the 60's as an ignition ballast resistor. It's not so muchan inrush item as limiting current once a circuit is in operation. When it's cold ( startup, or colder conditions ) the resistance is low allowing more current. Once the circuit starts operating, current warms the PTC, raising the resistance and lowering the current. This allows the PTC to cool, lowering the resistance. At some point it will reach an equilibrium state based on demand (varying in a car, stable in a CFL) and ambient conditions.
What a great instructable! This is the best information on CFLs I found so far, most pages &quot;informing&quot; about them don't mention the electronics inside at all. The comments were great too. I have a couple CFL questions, maybe someone here knows: Taking macro photographs and using a 30 watt cfl as light source made me wonder; Is the light from a CFL more damaging to the eyes than a &quot;normal&quot; incandescent? And does it depend on the color of the light (2700k vs 6500k for instance). I had one quit on me with a popping sound, could that have been the electrolytic capacitor exploding? I have a little fan connected to my computers USB, I notice I can make it stop by pointing the CFL close to it. Magnetic field?
I never thought about the caps overheating and dying. I have several lights in my ceiling, and the CFL's only last a few months. Whereas the CFL's in normal lamps which get plenty of ventilation have never died on us. I was originally interested in taking these bad boys apart in order to make them into LED bulbs.
your mention of the mercury reminds me of a time when one of my friends accidenally bumped a cfl bulb. when it didn't turn on, he just threw it out. a couple days later, his mom was throwing up because of the mercury and other toxic gases that were just floating around
&nbsp;omg was she okay? I just broke one and I'm freaking out cuz I slept in the room all night and I didn't know it was broke D:
yeah, she was okay, she just felt a little nauseous for about a week or so. dont worry, you arent going to die
I took apart a broken one and could not believe all the electronics on the little board. I can see whey people said they could make radios and all kind of stuff with one. When you learn about science, you look at things so much differently. So glad I took physics in college.<br />
Thanks , instructable was very educative.<br />
That is where they get the term, Mad as a Hatter, (yes Dawp, I&nbsp;dated myself too)&nbsp; <br /> <div id="refHTML">&nbsp;</div>
how much voltage would you say the CFL needs to operate?can it work with 330 volts from disposable camera?
Now THAT's an interesting question. CCFL inverters like the one shown tend to provide more than 330V, at least for "ignition", but they don't need much more than 110V to actually run. (The whole "startup" thing is complex in fluorescents.) Disposable camera inverters are not very efficient, and don't put out very much power overall, but it WOULD be neat to get any light at all out of a CFL from a 1.5V battery!
I've tried to use a CFL off a capacitor, It won't work unless you can have a higher voltage to strike it, I used a piece of wire connected to the trigger transformer to light the CFL.....
i've seen joule thief circuits built to power a CFL from a 1.5 volt battery. it's sweet.
a ccfl inverter will light even a dead tube providing it has vacuum(800v)!<br />
Awesome, I took apart some of those things and didn't know what I could do with them yet; thanks a lot ^^<br />
Three little buggers, but now comes the hard part; utilization.
Very nice, but I couldn't help noticing the chicken leg bones... May I ask what's in store for them?
I usually tell fortunes for anyone willing to throw the bones, but most are afraid of what the bones will tell me. I cooked them, bleached them, and processed them the best I could, and they now sit in a baggie waiting to be used for a million costumes I need to finish making. Oh, if you could see the dismantling heaven/hell I have going on now. Two digital cameras being harvested for parts after their plastic gears were thrashed by lens slams. I have bags of material and skinned stuffed animals also waiting to be processed. To many things going on, but maybe, just maybe I'll instructisize something. Peace.
Hahah...Thanks for indulging my curiosity! Sounds similar to my play space. Don'tcha distrust neat freaks? They lack creativity IMNSHO. I also have some bones. Except I drilled them and gave them the magic of the compass...
Hi: I used to take rib bones. Cut them to about five inches, drill and tap to 8/32 at each end, and use them as drawer pulls and carrying handles. They last forever, unlike what was once on the bones:). I had some neat antique glass knobs on some drawers and cabinets in a house i sold. I wanted to keep the knobs, so guess what is maybe still on the drawers and cabinets:) Interesting what forgotten kluges this site brings to mind.
I boil skeletons and bones, remove the meat with a nail brush, bake it really low in the oven for about an hour then dip it in polyurethane. Makes nice assembled skeletons and necklaces etc...
About This Instructable
192,586views
292favorites
License:
Bio: Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
More by westfw:Visualizing EAGLE Edits with a Gerber Viewer Make a Double CD/DVD Case From a Single Sheet of Paper Single Sided Really Bare Bones Board Arduino in EAGLE.
Add instructable to:
