3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Take apart an optical mouse
Dr Destruct-o takes apart a couple of Microsoft Explorer Optical "IntelleMice", to see if there are any useful goodies inside.
Step 1Here we have a couple of still-together mice
These seem to show up with some regularity in the E-waste bins at work. I don't know if the Microsoft mice are more prone to failure than other mice, but they're certainly more recognizable in the waste bin.
One of these says "version 3" on the bottom sticker, and the other doesn't. They're USB mice, although apparently they'll talk PS2 as well, using a merely physical adapter (these adapters don't actually translate between PS2 and USB protocols, they just connect the wires differently. The processor inside the mouse detects which kind of connection is in use, and reconfigures its pins as appropriate.)
12 comments
Aug 10, 2010. 3:30 PManthonyyy0 says:
you obviously know a lot about mice right? If i took an optical mouse apart would it have tact switches inside for the left/ right mouse click buttons? if not would i be able to solder tact switches to the places where the left/right clickers/buttons hit the board so that i can relocate buttons? (Im making a NES Mouse :D) Thanks for any help you can give!
Sep 9, 2009. 1:39 PMColonel88 says:
nice ible i REALLY want to change the mouse so the bottom light thingie was blue so then it would look mad kewl.
Aug 27, 2009. 1:24 PMomnibot says:
Is there some software to let you use this in any way you like? I'm thinking robotics where the optics could be used for positioning, the wheel for touch-sense and the buttons as bump-detectors. Any suggestions? I've seen some use a PIC as an adaptive interface but software to change it's use from a PC-based robot?
Jun 2, 2009. 6:35 AMpurple shirted eye stabber says:
lol i have the same mouse too. other than that great instructable 4/5 stars. (i have more than one of these) (i have an army of mice) lol im crazy
Aug 13, 2008. 11:12 PMEaglesNestOne says:
U have same mouse i'm using lol. Give you stars just for that lol ;D
May 14, 2008. 5:14 AMTechnoMancer says:
the DIP through hole sensor is probably more useful to you they do have documentation on the protocols usually I2C or SPI
Apr 1, 2008. 5:53 PMCharlie1138 says:
I have a logitech mouse I was trying to take apart to make some other project and it looked like there was no solder under the microswitches on the pins.. it also seemed like there was a plastic coating on the bottom of the circuit board holding those pins in.. have you seen anything like this? I tried to heat the solder and scrape it off the pins(if there was any there) but it seemed like there was no sodler there or maybe I didn't have my soldering iron hot enough?
Dec 27, 2007. 1:09 PMstasterisk says:
Have you ever used the optical bits to get position feedback on your robot?
Nov 26, 2007. 4:17 PMGorillazMiko says:
coollllll :-)
Nov 26, 2007. 1:57 AMll.13 says:
Two LED's I'm guessing the tail LED is for eye candy? 0.o
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
