3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Take apart an optical mouse
Step 5Easily Desolderable
Easily Desolderable
Some components are more easily de-soldered from a PCB than others. Through-hole parts with three pins or less are pretty easy to remove using solder-wick, for example.
1) Each of these mice has five micro-swicthes; relatively nice SPDT ones that might be useful
2) Infrared emitter and "direction detector" as part of the mouse wheel. In the mouse wheel, which is also optical, there's a two lead part that is an infrared LED, and a four-lead part that is dual photo-transistor or (perhaps) more complex circuit that outputs signals sufficiently complex for the microcontroller to tell which way a slotted wheel (turned with the mouse wheel) is turning. This is all on a nice separate board; with a bit of mechanical skill you might be able to use the wheel separately from the rest of the mouse.
3) The new version of the mouse has a three-pin 6MHz (a common speed for USB things) ceramic resonator hiding under that metal can. (A three pin resonator replaces a crystal and two caps in most microcontroller circuits.) The older version has two 2-pin resonators (somewhat less useful IMO.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
