With the help of various other tutorials on similar laptops, I was able to disassemble my Vaio with relative ease and fix the problem. I will go over these instructions in hopes that this maybe useful to someone else in the future. Opening up a Vaio is kind of an intricate process. With a laptop, you never want to tug and pull too hard as pieces are generally very small and hard to replace.
Most people who will need this will probably only need to know how to disassemble the laptop and not fix the power issue. However, I've added my fix for that problem just in case.
Last but not least, keep in mind, I'm not an Âexpert. These directions are not from the manufacturer and should not be considered as such. Do this at your own risk.
This instructable originally appeared on my website at Verbal Caricature.
Remove these ads by
Signing UpStep 1Be Carefull.
img1.classistatic.com/cps/kj/100603/953r5/52388c6_20.jpeg See that lovely sleek barrel connected housing? Well I was watching a movie running from the laptop to the TV with HDMI, in the dark, I got up to use the bathroom, tripped over the power cable, ripped out the HDMI, sent the laptop (literally) about 12 feet across the floor, snapped that barrel clean off...luckily the wiring remained intact...and I glued it back together..the plug still feels horribly loose, but has no issues with cutting in/out etc.
Thanks for a great instructable!
Thanks - a great post.
Gary
Wisbech
UK
First, do not push the VGA connector in; this is stationary and attached directly to the motherboard.
Second, by my estimation, there are a couple different kinds of stuck. 1) There's the kind of stuck where there can be no other explanation other than there must be a screw or plastic push piece holding it in place or 2) there's the kind of stuck where if you jiggle it lightly it might come apart. The second kind of stuck is also more likely if you cause some sort of cosmetic damage to the right side of the case. When I dropped my laptop, I caused some cosmetic damage to the right rear corner of the laptop and was preparred to feel a little bit of extra resistence there. I do not know what your scenerio is but if that's the case (no pun intended), feel it out.
Keep in mind that Sony wouldn't make it impossible to take apart because if you sent it in for repair, the more parts they had to break to get in, the more parts they'd need to replace and the more money it would cost them. If it helps, take a break and regain your composure. I often get irritated and then become a Neandrathal and break stuff if I don't cool off for a moment.
I know that when I did it, it certainly felt more stuck in some spots. I just felt it out and tugged only hard enough to get it loose. You can kind of estimate the amount of pulling the plastic can take.
Other than that man, I got nothing. Good luck and let me know how it goes.
