Taking the Strain Out of Changing a Tire.
Published
Introduction: Taking the Strain Out of Changing a Tire.
The video kind of says it all. The air tank makes it quick and easy, but if you don't have one, a bicycle pump would work, or one of those car tire inflators that plugs into the cigarette lighter.
I came up with this idea after I had a blow out on the trailer you see in the video about midday when the temperature was about 95 degrees. The shoulder of the road was a steep slope and it took me forever sweating bullets to get that wheel on trying to line up lugs bolts that kept spinning around while trying to hold the 60 pound wheel up in place against down hill force. It was murder. It's a wonder I didn't have a heat stroke out there at 71 years old.
My inner tube would have been a life saver in that situation and would have kept the tire held up and stable while i worked with the hole alignment.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Coming home from work at 3am, I do not want to change a tire. I always have a flashlight and TWO cans of FIX-A-FLAT.
    Yep, a few cans of Fix-a-flat is a good thing to have with you. In my case, tire chunks was all over the road. Sometimes on a flat, the bead will pull away from the rim and not even 100 pounds of air will puff it back out enough to hold any kind of pressure. I've had that happen. Takes an Air Bead Seater tool. I'd like to have one laying around.
    Break it loose
    Jack up just off the ground
    Put a wedge chock between ground and tire and continue
    Reverse to put new back.
