Talking Arduino Halloween Skeleton
59,154
178
35
Posted in HomeHalloween
Introduction: Talking Arduino Halloween Skeleton
Welcome to another of my instructables!
So Halloween is upon us again and I really wanted to use the Arduino I had.  I went to the halloween store and found a skull with a hinged skull and that was the spark that began this project.  I knew that it would probably be easy to have a servo move using the arduino and have it move the skull jaw up and down.
Step 1: Gather Your Materials
you'll need stuff.  Lots of stuff.  Well...not lots of stuff, but stuff from different places.  Here's a sort of breakdown of all the stuff I used and where I got it.
Arduino Duemilanove - $34.99
http://www.makershed.com/ProductDetails.asp?ProductCode=MKSP4
Ladyada Waveshield Kit - $21.95
http://www.makershed.com/ProductDetails.asp?ProductCode=MKAD11
2 Super Bright Red LED's - $1.79 for a 2 pack
http://www.radioshack.com/product/index.jsp?productId=3096133
PIR Sensor Module - $9.99
http://www.radioshack.com/product/index.jsp?productId=2906724
A small servo - around $13.00
Bought it at a RC hobby shop here in town
A skull - around $9
A black cloak halloween costume - around $10
various bones
Speakers
Wire
PVC and fittings - from lowes or home depot
hmmm.....seeing it all written out it seems like more money that I remember spending...haha.  Still though, to get animatronic halloween things premade you'd spend a bunch more that that.  That's what I'll keep telling myself to justify this.
Step 2: Build the Sound Shield
first thing you need to do is build your sound shield.  To save from repeating the wonderful step by step tutorial that lady ada made for her sound shield, I'll just put the link here to it.  One thing to note, I had the older version of this shield and didn't realize I was looking at the newer instructions until she was telling me to install pieces that I didn't have.  haha.  Make sure you are looking at the correct instructions before you start soldering.
V1.0 instructions
http://www.ladyada.net/make/waveshield/solder10.html
V1.1 instructions
http://www.ladyada.net/make/waveshield/solder.html
Step 3: Wire Up LED's
So here's how the LED's were wired up.  They are being fed 5v from the Analog 4 spot on the arduino.  What's great about this is that the arduino feeds out 5v, the LED's each require 2.5v, so the two of them are perfect for each other.
Step 4: Wire Up Motion Sensor and Servo
Here's how the motion sensor and servo are connected up.  these diagrams are done this way because I hooked all the wires in the skull up to a small project circuit board and then used CAT-5 Network Cable to run it down to the arduino.  The network cable allowed me to have more than enough wires to run everything I needed in one convenient package.
Step 5: All Together Now!
Here's the whole set up for the wiring in the skull.  Looks fairly simple in diagram form I think...
Step 6: One Other Thing...
You need to get a voltage reading of what the power of the audio is.  What this allows is whenever the volume on the sound gets loud enough, it opens the mouth of the skull.  Then when the voltage drops, the servo closes the jaw.  Fairly simple.  We'll attach a wire from a resistor and plug that wire into one of the inputs on the arduino so we can read it in the code.
Step 7: Put Some Wav's on Your Card!
Grab yourself 4 wav files and format them as the lady ada tells you they need to be formatted.  If you want to use my code as is, you'll have to label them as follows on the card.  If you can figure out my code, you can just rename them to whatever you change the code to.  Anyways...use these names if you don't want to modify anything:
1.wav
2.wav
11.wav
13.wav
Step 8: Hook Up the Arduino
Hook up your arduino to the computer, copy and paste this code, and put it on your arduino.
If the code isn't visible below, I included a txt file of it so you can just download it that way.
#include
#include
#include "util.h"
#include "wave.h"
#define DEBOUNCE 100
#define swPin 14
#define eyeleds 18
AF_Wave card;
File f;
Wavefile wave;
int inputPin = 8;               // choose the input pin (for PIR sensor)
int servoPin = 16;              // choose the input pin (for Servo)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status for motion sensor
int minPulse     =  600;  // minimum servo position
int maxPulse     =  2200; // maximum servo position
int turnRate     =  1800;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  20;   // time (ms) between pulses (50Hz)
int mouthchange = 6;  //checks to see if mouth position needs to be changed
int randNumber;   //random number variable to allow the choosing of which wav will be played
/** The Arduino will calculate these values for you **/
int centerServo;         // center servo position
int pulseWidth;          // servo pulse width
long lastPulse   = 0;    // recorded time (ms) of the last pulse
void setup() {
  // set up serial port
  Serial.begin(9600);
  pinMode(inputPin, INPUT);     // declare sensor as input for PIR
  pinMode(eyeleds, OUTPUT);     // declare sensor as output for eyes
  // set up servo pin
  pinMode(servoPin, OUTPUT);  // Set servo pin 18 (analog 4) as an output pin
  centerServo = maxPulse - ((maxPulse - minPulse)/2);
  pulseWidth = centerServo;   // Give the servo a starting point (or it floats)
  // set up waveshield pins
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // open memory card
  if (!card.init_card()) {
    putstring_nl("Card init failed!"); return;
  if (!card.open_partition()) {
    putstring_nl("No partition!"); return;
  if (!card.open_filesys()) {
    putstring_nl("Couldn't open filesys"); return;
  if (!card.open_rootdir()) {
    putstring_nl("Couldn't open dir"); return;
void loop()
  val = digitalRead(inputPin);
  if (val == HIGH)
    if (pirState == LOW)
      // we have just turned on
     Serial.println("Motion!");
     //Turn eyes on
     digitalWrite(eyeleds, HIGH);
     // Play a sound:
     randNumber = 0;
     randNumber = random(3);
if (randNumber >= 1)
     randNumber = randNumber + 1;
     Serial.println(randNumber);
         if (randNumber == 1)
           playcomplete("11.WAV");
        else if (randNumber == 2)
            playcomplete("2.WAV");
        else if (randNumber == 3)
            playcomplete("13.WAV");
        else if (randNumber == 4)
            playcomplete("1.WAV");
      pirState = HIGH;
  else
    if (pirState == HIGH)
      digitalWrite(eyeleds, LOW);
      // we have just turned off
      Serial.println("Motion ended!");
      // We only want to print on the output change, not state
      pirState = LOW;
void playcomplete(char *name)
  char i;
  uint8_t volume;
  int v2;
  playfile(name);
  while (wave.isplaying)
      volume = 0;
      for (i=0; i<8; i++)
        v2 = analogRead(1);
        delay(5);
   if (v2 > 440)
           pulseWidth = 1800;
           mouthchange = 1;
           else
           pulseWidth = 800;
           mouthchange = 1;
  digitalWrite(servoPin, HIGH);   // start the pulse
  delayMicroseconds(pulseWidth);  // pulse width
  digitalWrite(servoPin, LOW);    // stop the pulse
  card.close_file(f);
void playfile(char *name)
  // stop any file already playing
  if (wave.isplaying)
    wave.stop();
    card.close_file(f);
  f = card.open_file(name);
  if (f && wave.create(f))
    wave.play();
Step 9: Test It!
I'm sure there's some other little things I've left out.  I'll continue to add to this as I remember.  This project took me over a month and grew larger and larger as I bought more things to add to it.  If it doesn't work, and you've followed all my instructions, dig deeper!  This isn't an end all, be all instructable!  Part of the fun in these projects is making it your own.  This project came about from me combining lots of other arduino projects I've seen around the web and that really is the best way to learn new things!  Have fun!  Experiment!
Halloween Contest
Third Prize in the
Halloween Contest
2 People Made This Project!
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
35 Comments
Hi,
Great Instructable! Would this work on the Uno?
Hey! Most of the links aren't working for the parts as of July 2016. Does anyone have an updated parts list, per chance? <3
I need hints on communicqtion wiyh getti freq
Oh and thank you so much! This tutorial is awesome! I really hope you make more videos and tutorials in the future!
Ivogt I just got the WaveHC code working last night. I'll post the update after I get finish updating the servo code if I can. Probably a day or two.
Has any one modified this code to work with the latest version of WaveHC library?
Newbie needs help. Thanks.
Very spooky! Love it.
I've met the creator of arduino and he signed my shirt
getting to be that time again. planning Halloween stuff for this year.
how hard would it be to combine the mouth movement of this project with LED backpacks like here?
http://learn.adafruit.com/animating-multiple-led-backpacks
I'd love to have the mouth move and also have the creepy moving LED eyes in RED.
Since you'd be using Adafruit products for both the sound playback and the LED eyes, why not ask on their forum?
Nice Instructable, and the project looks good. But....For less money than what you spent for the 2 Arduno boards and the aggrivation of putting them together you could have bought a Scary Terry Audio servo driver board From Cowalicious for $42.95 which is pretty much plug and play....Your Arduino kit comes to about $56.94. Just Curious as to why you did it that way.
Hey!
Very nice instructable! I am searching a while, could please tell me somebody where to buy a skull like the one in the instructable. Best will be when i can buy it in germany or austria.
Thanks!
Have you tried: http://www.skeleton-factory.com/ ?
Has anyone converted this for use with the WaveHC library, by any chance? I'm a total newbie to Arduino and stumbling through it at the moment.
is there a way to make the servo quiet it seems a litlle loud
i get 9 error #include expects filename
sorry my key boards broke so some keys dont work, but yeah i compile this and get that error message is there anything i have to add, i need this by halloween.
Make sure you include Ladyada's AF_Wave library from her site for the Wave Shield
Also missing in the code here, there are 2 Include statements that are blank right at the top of the code. "Instructables doesnt like the "<>" symbols posted in the code and it dropped the information after the #include statement. I typed out the names of the symbols here before and after the information that is required.
The first one should be #include (less than symbol) AF_Wave.h (greater than symbol)
The second one should be "#include (less than symbol)avr/pgmspace.h
It took me a bit to figure out (i'm new to arduino and not a programmer) looking at other examples of code lead me to change those two include statements
I loaded the code last night (without a servo hooked up yet) and the wav portion works no problem.
Cheers
Great Instructable. Anxious to re-task Mr. Skull!  When I try to verify the code on my Arduino, I get an error (looking for a particular filename). Any Ideas?
could be a library you are missing.  Take that error that you are getting and type it into google.  Whenever I had an error happen like that I was missing an arduino library I just had to download and throw into a folder.  Good luck!  Hope this helps!
