3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Talking Arduino Halloween Skeleton
Step 8Hook up the arduino
Hook up your arduino to the computer, copy and paste this code, and put it on your arduino.
If the code isn't visible below, I included a txt file of it so you can just download it that way.
#include
#include
#include "util.h"
#include "wave.h"
#define DEBOUNCE 100
#define swPin 14
#define eyeleds 18
AF_Wave card;
File f;
Wavefile wave;
int inputPin = 8;               // choose the input pin (for PIR sensor)
int servoPin = 16;              // choose the input pin (for Servo)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status for motion sensor
int minPulse     =  600;  // minimum servo position
int maxPulse     =  2200; // maximum servo position
int turnRate     =  1800;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  20;   // time (ms) between pulses (50Hz)
int mouthchange = 6;  //checks to see if mouth position needs to be changed
int randNumber;   //random number variable to allow the choosing of which wav will be played
/** The Arduino will calculate these values for you **/
int centerServo;         // center servo position
int pulseWidth;          // servo pulse width
long lastPulse   = 0;    // recorded time (ms) of the last pulse
void setup() {
  // set up serial port
  Serial.begin(9600);
  pinMode(inputPin, INPUT);     // declare sensor as input for PIR
  pinMode(eyeleds, OUTPUT);     // declare sensor as output for eyes
  // set up servo pin
  pinMode(servoPin, OUTPUT);  // Set servo pin 18 (analog 4) as an output pin
  centerServo = maxPulse - ((maxPulse - minPulse)/2);
  pulseWidth = centerServo;   // Give the servo a starting point (or it floats)
  // set up waveshield pins
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // open memory card
  if (!card.init_card()) {
    putstring_nl("Card init failed!"); return;
  if (!card.open_partition()) {
    putstring_nl("No partition!"); return;
  if (!card.open_filesys()) {
    putstring_nl("Couldn't open filesys"); return;
  if (!card.open_rootdir()) {
    putstring_nl("Couldn't open dir"); return;
void loop()
  val = digitalRead(inputPin);
  if (val == HIGH)
    if (pirState == LOW)
      // we have just turned on
     Serial.println("Motion!");
     //Turn eyes on
     digitalWrite(eyeleds, HIGH);
     // Play a sound:
     randNumber = 0;
     randNumber = random(3);
if (randNumber >= 1)
     randNumber = randNumber + 1;
     Serial.println(randNumber);
         if (randNumber == 1)
           playcomplete("11.WAV");
        else if (randNumber == 2)
            playcomplete("2.WAV");
        else if (randNumber == 3)
            playcomplete("13.WAV");
        else if (randNumber == 4)
            playcomplete("1.WAV");
      pirState = HIGH;
  else
    if (pirState == HIGH)
      digitalWrite(eyeleds, LOW);
      // we have just turned off
      Serial.println("Motion ended!");
      // We only want to print on the output change, not state
      pirState = LOW;
void playcomplete(char *name)
  char i;
  uint8_t volume;
  int v2;
  playfile(name);
  while (wave.isplaying)
      volume = 0;
      for (i=0; i<8; i++)
        v2 = analogRead(1);
        delay(5);
   if (v2 > 440)
           pulseWidth = 1800;
           mouthchange = 1;
           else
           pulseWidth = 800;
           mouthchange = 1;
  digitalWrite(servoPin, HIGH);   // start the pulse
  delayMicroseconds(pulseWidth);  // pulse width
  digitalWrite(servoPin, LOW);    // stop the pulse
  card.close_file(f);
void playfile(char *name)
  // stop any file already playing
  if (wave.isplaying)
    wave.stop();
    card.close_file(f);
  f = card.open_file(name);
  if (f && wave.create(f))
    wave.play();
5 comments
Oct 5, 2010. 6:23 PMbalak95 says:
i get 9 error #include expects filename
sorry my key boards broke so some keys dont work, but yeah i compile this and get that error message is there anything i have to add, i need this by halloween.
Oct 27, 2010. 7:25 AMArchos_User says:
Make sure you include Ladyada's AF_Wave library from her site for the Wave Shield
Also missing in the code here, there are 2 Include statements that are blank right at the top of the code. "Instructables doesnt like the "<>" symbols posted in the code and it dropped the information after the #include statement. I typed out the names of the symbols here before and after the information that is required.
The first one should be #include (less than symbol) AF_Wave.h (greater than symbol)
The second one should be "#include (less than symbol)avr/pgmspace.h
It took me a bit to figure out (i'm new to arduino and not a programmer) looking at other examples of code lead me to change those two include statements
I loaded the code last night (without a servo hooked up yet) and the wav portion works no problem.
Cheers
Nov 15, 2009. 9:04 PMlarsen e whipsnade says:
Great Instructable. Anxious to re-task Mr. Skull!  When I try to verify the code on my Arduino, I get an error (looking for a particular filename). Any Ideas?
Nov 5, 2009. 5:14 PMbill2009 says:
for some rason I can't see the code.  Is it posted directly somewhere?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:samseide(SamuelSeide.com)
