Introduction: Talking Arduino | Playing a MP3 With Arduino Without Any Module | Playing Mp3 File From Arduino Using PCM
In this instructables we will learn how to play a mp3 file with arduino without using any audio module, here we gonna use PCM library for Arduino which plays 16 bit PCM of 8kHZ frequency so lets do this.
Step 1: Gather Your Components
BUY PARTS:
BUY TIP120:
https://www.utsource.net/itm/p/384328.html
BUY 12V ADAPTER:
https://www.utsource.net/itm/p/8013134.html
BUY ARDUINO UNO:
https://www.utsource.net/itm/p/7199843.html
so in order to do this we need a few components very firat An Arduino & then a speaker 0.5w to 10 w any speaker will do the job then you need to buy a transistor for amplification if your speaker is higher than 0.5w as mine was 3 w so i used a TIP 120 transistor dor amplifying the audio you can use any audio amplifier too.
Buying links. -
Items to Buy (affiliate link) -
Arduino Uno-
https://www.banggood.com/UNO-R3-ATmega16U2-AVR-Mod...
Speaker -
https://www.banggood.com/2-Pcs-3-Inch-4-10W-Full-R...
https://www.banggood.com/50MM-0_5W-Customized-50mm...
https://www.banggood.com/3-Pair-4-Ohm-3W-LCD-Panel...
TIP 120 transistor -
https://www.banggood.com/10pcs-TIP120-NPN-TO-220-D...
Step 2: Connections
The connections are really simple if you are using 0.5watt speaker then directly connect the +ve pin of speaker to digital pin 11 on Arduino & -ve pin of speaker to gnd & if using 3 watt speaker then use a tip120 transistor & connect the 11 of Arduino to the base of transistor and -ve pin of speaker to the collector of the transistor & emitter of the transistor to the gnd pin on Arduino.
IIf having issues with connection refer video for help.
Step 3: Download Required Files
To do this you will need few files first of all PCM.zip file to play PCM audio from arduino.
ThEN we will need Audacity software to convert a normal mp3 audio to a 16bit PCM 8hkz audio
& Lastly we need a encoder software to encode that audio into data which we can paste in the code.
DOWNLOAD Audacity -
https://www.audacityteam.org/download/
Download PCM.ZIP & Encoder software (file named as Arduino MP3.zip) -
Step 4: Prepare Audio & Convert It Into Data
the important step is to prepare the audio data.so very first we will need a mp3 file either you record one or get one from anywhere then open that file into Audacity and & click on format then select 16 bit pcm then go down & select frequency of audio to 8000hz & export the audio as mp3.
Then open encode audio software & navigate to the audio file we generated froma audacity then you'll get a message audio copied to clipboard successfully.
Step 5: Coding Part
so the next part is coding part , so as you downloaded the the Arduin mp3.zip file which contains PCM.zip file so add this PCM.zip file as a library to the arduino & then open the playback example available in the that PCM library , & there in the sketch you have to edit the 2nd line of code in sample[] arrray which is of programem type you need to remove all the data in that aray & paste the data which is copied to the clipboard by the encode audio software.
Step 6: Upload the Code
so finally our code is ready so upload it to the arduino & you'll hear your recorded audio from speaker , enjoy it & if you have any issues or want to about this in deep just refer the video provided.
Thank you.
