3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tang Survival kit
Tang Survival kit
I have seen a lot of survival kits on this site.  Most of them are all contained in a altoid tin.  I think that they are missing a few items that would make them more affective.  Anyways here is mine.  Let me know what you think or if I am missing something.
Step 1Things needed:
Things needed:
I will explain what each one does.
Here is the list:
1- LED Flashlight
3'- 12 gauge stranded wire with sheathing removed
1- Simple knife
30' - String
1- Box of waterproof matches
1- Magnesium flint
3- Nuts
1- Bottle of Iodine tablets
5'- Duct tape
1- Platsic grocery bag
1- Ziplock baggy
1- 3'X3' sheet of tin foil
1- 1'X3' sheet of saran wrap
1- Ball type compass  (they're smaller than most and work better than most of the cheapys)
1- Large needle
1- Replacement sling shot strap
1- Condom
1- Hand sanitizing wipe (individual packet type)
1- Razor blade  ( I made a small cardboard sheath for it)
1- Emergency Blanket
1- 3'' piece of plastic tubing
1- Butane lighter
1- Smaller container containing cotton balls covered in petroleum jelly and dryer lint.
1- Small bag of char cloth  (not pictured)
1- Fishing kit (Contains: 2 mini bobbers, 2-20' folls of 8 lbs fishing line, 1- 20' roll of spider wire fishing line, and a assortment of small hooks.  They all are kept in a 35mm camera case).
16 comments
Aug 23, 2011. 1:57 AMUrbanNinjaOokami says:
Don't forget a few basic medical supplies. In a survival situation, the smallest cut can get infected and get you killed. A little Liquid Skin and Alcohol Swabs and Bandages can go a long way.
Jun 10, 2011. 7:35 PMZaphod Beeblebrox says:
add a real knife (swiss army's are better for taking apart stuff) like something from kershaw or gerber, etc. and paracord and use a metal container instead of the tang one (so you can put it over a fire)
Mar 21, 2010. 6:32 AMtaterkiller says:
i would include a map
Mar 30, 2010. 10:22 PMk1717 says:
i thought the whole kit was pretty thourough but i omly saw string and wire that can be used for tying stuff ect.. maybe add some paracord or some other thin but strong cord? liked the instructable though
Jan 28, 2011. 11:42 PMcalloforion says:
One of the best kits I've seen. I really like that the container can double as a cup/bowl. I also wanted to add that the iodine tablets can be made into a past for cleansing wounds and such as well. Really neat kit, man.
Jun 6, 2010. 9:13 AMNicholas G. says:
Don't use the almonds for bait!!! Instead, you should eat them yourself providing that you are not alergic. They are high-protein and will give you a very solid energy boost.
Dec 28, 2009. 10:06 AMstrods says:
Add a clear plastic sheet (think window insulation or saran wrap) and you can make a solar still with a longer tube and the tang cup
Dec 20, 2009. 6:19 PMpyra_builder_1337 says:
its much better than most of the ones you see on the interweb
Dec 15, 2009. 10:07 PMl8nite says:
You may want to add someway to purify water and maybe some gum otherwise it seems like a good kit to carry
Dec 16, 2009. 11:44 PMl8nite says:
sorry... I read the list 3x and still missed them..  its no fun getting old....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tjk888
